5 lug conversion ???
Old Apr 8, 2009 | 08:52 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Ive seen some in Thailand I believe? They were K20.
Old Apr 10, 2009 | 04:16 AM
FELIXY69's Avatar
how about re drilling the hub...?
ppl re drill rotors from 4-5 lug...
y not with the hub ???
any thoughts ??
Old Apr 15, 2009 | 10:31 PM
k20gd3's Avatar
anyone else have any other ideas? i would love to get this done but dont want to go the sapcer/adapter route
Old Apr 17, 2009 | 05:42 AM
FELIXY69's Avatar
i don't think u can get 4X100 - 5X114.3 conversion spacers
if so....can u show me an example ?
Old Apr 17, 2009 | 05:57 AM
Type 100's Avatar
Fronts from the DC5 should be a semi bolt up. Its VERY similar. The rack is way different though. Rears... IDK? Their rear suspension is pretty similar. It wouldnt hurt for someone to see if the Fits rear spindle and the RSX rear disc/hub will work.
What about the later Ep3's? They were 5lug.
Hmmm...come to think of it, I don't remember what J's Racing did for their K20/K24-hybrid Fit GT time-attack car's rear lugs. That was 5-lug I believe...I'm sure they also used DC5 front suspension.
Maybe I should check out its appearance in "VTEC Club Vol.5" again.
Old Apr 17, 2009 | 10:16 AM
Fit4Trav's Avatar
Here's a link to someone selling some. Made by GTO in Japan
GTO 4 to 5x114.3 lug adapters 20mm - Scion xB Classifieds - Scion xB Forum
Old Apr 17, 2009 | 11:56 AM
redrumm's Avatar
talk about some weight
Old Apr 17, 2009 | 12:40 PM
Daemione's Avatar
Not to mention you'd need 20mm more offset on your wheels . . .
Old Apr 17, 2009 | 01:16 PM
projekz's Avatar
So you'd need 55 to 60 offset wheels to pull this off?!?!?!?
Old Apr 17, 2009 | 02:21 PM
Sugarphreak's Avatar
Push My Button
That or fender flares with a 45 degree negitive camber
Old Apr 17, 2009 | 02:34 PM
khanhdom's Avatar
20mm is thin compare to others out there
Old Apr 24, 2009 | 01:36 AM
  #32
FELIXY69's Avatar
i don't think i wanan get a spacer...
perfect wheel fitment means without the use of additional parts to make it perfect....other wise is not really "perfect"
Old Apr 24, 2009 | 11:25 AM
  #33
Daemione's Avatar
any one else got any other ideas?
What's the motive for wanting 5 lugs vs. 4?
Finding good wheels used to be a reason . . . but there are just as many (or more) offered in 4x100 as the 5x114.3 spacing.
Old Apr 28, 2009 | 07:44 AM
  #34
Jesse's Avatar
easiest way to do it is to take hubs off....have them welded, indicate hub bore, redrill. We used to do a lot of this type work in the 1990's for football/basketball/baseball players in Texas. they all wanted wheels that wouldnt fit their cars lol. we did one of two things.
either made the car the bolt circle they needed or made adapters. you can even go as far as having new hubs made from a machine shop.
Old Apr 28, 2009 | 12:34 PM
  #35
projekz's Avatar
Getting hubs made by a machine shop seems to be the way to go. It won't be cheap but it'll be done properly.
Old May 7, 2009 | 05:50 AM
  #36
k20gd3's Avatar
i was just trying to go the oem route
Old May 24, 2009 | 05:08 AM
  #37
FELIXY69's Avatar
not at all....how are you gonna fine VIP deep dish wheels in 4X100 pattern ?
Old May 24, 2009 | 04:02 PM
  #38
projekz's Avatar
Check out them 10th post from the top in this thread:
https://www.fitfreak.net/forums/fit-...y-ge8-fit.html
Old Jun 24, 2009 | 09:32 PM
  #39
k20gd3's Avatar
wow i guess there is hope!? guess that would work for temp till an actual oem combo comes out. =]
Old Jun 27, 2009 | 07:52 AM
  #40
FELIXY69's Avatar
c i told u it would work !
now i gota find my self a set of hubs for redrill !
