New Tires sag
Old Dec 30, 2009 | 12:58 AM
Lek's Avatar
Lek
New Tires bulgy
Today I bought a set of Bridgestone MY-01 Sport Touring tires for my wifes new Honda Fit from Bridgstone Thailands main dealer.
They are 195/55/R15 (85v) on 15"x5.5 mag wheels.
http://www.bridgestonetyre.com.my/at...age.aspx?pn=22 .
The problem is they look like they are bulging or sagging and under inflated, but the tire pressure is perfect.
Is this normal for this type of tire?
Old Dec 30, 2009 | 02:34 AM
Hootie's Avatar
If the bulging that you are referring to is the tire sidewall protruding pass the rim, then that seems normal. The reason this is happening is that the inner lip of the tire that makes contact to the rim is wider than the rim itself, so it sinks the inner part of the sidewall in. If you rim was wider (say 7 or 7.5 inches) then the effect would be reversed; causing the inner section of the sidewall to expand pass the sidewall itself.
Old Dec 30, 2009 | 02:43 AM
Lek's Avatar
Lek
My wife even noticed that they look under inflated and too big for the wheel. Like wearing baggy pants.
Old Dec 30, 2009 | 03:27 AM
doctordoom's Avatar
Supervillain
that's normal for radial tires (which yours are).
Old Dec 30, 2009 | 09:25 AM
NIGHTHAWKSI's Avatar
that looks a little excessive of a buldge.
whats the tire pressure?
and what are you reffering to for the correct pressure?
Old Dec 30, 2009 | 09:30 AM
Lek's Avatar
Lek
Cold 32 psi front & 30 psi rear
Old Dec 30, 2009 | 10:25 AM
OEm psi recomendations are 32 front and 32 rear.
you have different trires though. the recomended psi may be different.
i also just realized you have a 195 tire on a 5.5" rim. that will cause to bow at the sides more alos since the tire is actually a littel too wide for that rim.
Old Dec 30, 2009 | 10:51 AM
FITMugen's Avatar
Base on OEM recommendation, the front tires should be 33 PSI and the rear tires should be 32 PSI. If your car has TPMS, the recommendation is 33 PSI for all tires.
Old Jan 1, 2010 | 05:13 AM
Lek's Avatar
Lek
The OEM Standard tires are 175/65/15 and my new tires are 195/55/15 which according to Bridgestone are fine for a 15x5.5 wheel.
I know this is a stupid question, but should the lower 55 profile tire give a bigger tire to fender gap.
Old Jan 1, 2010 | 03:03 PM
im the fit's Avatar
The higher the middle number the thicker the middle tire will be or taller........But a 195 tire in a 175 rim is your problem. You might also experience handling issues.
Old Jan 1, 2010 | 08:03 PM
Type 100's Avatar
Seems normal to me. I have the same bulge even on 16" tires at the same factory-spec air pressures.
Old Jan 1, 2010 | 10:24 PM
awptickes's Avatar
Looks normal for a 195/55 on a 15x5.5 wheel.
Charles Lasitter
Feb 24, 2025 01:10 PM
SevereService
Feb 16, 2012 05:13 PM
HomePhi
Feb 26, 2010 04:11 PM
Jetydosa
Jun 12, 2006 03:43 PM
verily
May 10, 2006 02:26 PM
