Sponsored by:
Sponsored by: CARiD
What's this hose??
Old Apr 22, 2008 | 11:17 AM
claymore's Avatar
What's this hose??
Mods not sure where this should be feel free to move it.
While looking at Sid 6.7 nice SSR intake post I happened to notice this hose connecting to the USDM intake manifold that I had never noticed before. (sorry Sid 6.7 for "borrowing" part of your engine photo).
It's just one more difference between the USDM version and the rest of the world models as we don't have that hose.
Has anyone that changed their intake systems or anyone with the USDM repair manual happened to notice where the hose goes on the right side of the photo? It looks like it is leading back toward the oil mist separator or it is a section of the engine breather.
Any clues from the USDM guys??
Old Apr 22, 2008 | 12:00 PM
koolkevin1107's Avatar
that is a coolant hose that runs some coolant through the opening of the intake manifold to keep it cool.
Old Apr 23, 2008 | 01:45 AM
claymore's Avatar
If that is for engine coolant then I would think it's more for intake manifold HEATING to warm the intake for better cold start warm-up emissions reduction like the water to the TB.
Running hot water through the intake would make it HOTTER not cooler like the TB setup so a cheap mod for you USDM guys would be to shut off the hot water to the intake.
If that hose continues on and is also the hose to the TB water supply the hose would be the perfect spot to splice in a shut off petcock valve. It would cut off hot water to the intake and the TB with one valve..... double whammy.
Old Apr 23, 2008 | 02:06 AM
quangalang's Avatar
im pretty sure that it's a vacuum line for the PCV valve
Old Apr 23, 2008 | 02:50 AM
claymore's Avatar
Anybody KNOW for sure?? The clamp looks like the ones used on water hose connections if you look to the left hose next to this one but this hose is a different color than the water one next to it.
Old Apr 23, 2008 | 03:00 AM
quangalang's Avatar
im pretty sure because there is a diagram for the PCV on the hood, and that hose is pictured.
the same clamp is used on the vacuum line from the brake booster to the intake manifold
Old Apr 23, 2008 | 03:42 AM
claymore's Avatar
Well that answers that if it's in that diagram then you get the golden ring.
b6130bui
Jun 20, 2017 01:19 AM
wzlfit
Apr 4, 2015 06:26 PM
pokems23
Aug 2, 2014 09:36 PM
jezzy's jazz
Feb 20, 2007 05:43 PM
