I did it, changed oil early.
Well, changed some. After hearing how much better the OEM filter is compaired to the "Fram" Honda that we get here, I left the filter in and just drained what was in the pan.
Why did I do it this way? Draining the pan only took out 3 quarts and hopefully all the random bits in the bottom. More importantly it left in 1.4 quarts of the magic "break-in" oil. I will leave it this way until 5000 when I switch over to synthetic and sample the oil again to see if my early change did any harm. I will post results from this sample when I get it back from the lab.
Cliff notes: Changed 3 quarts at 1488 miles and left OEM filter there, will send oil sample off to a lab for analysis.
well I changed oil yesterday at just a tad over 2k. changed filter also. lol, royal purple with a pure umm oilator filter or somethin. Guy recommended it over a fram which was $6 compared to $4 I think for the pure one. Next change'll come before winter. Also used 5-30 compared to 5-20.
The first oil service should not be done untill %15 on the panel. The factory oil is special, and only available from the factory in a new engine. After that change it to suit your self.. I use sys every 6 mo or 6000, with filter, which ever comes first.....
It's best to do both at once, but I would feel changing the filter is more important than the oil - when you're changing prematurely. The filter should be the one trapping contaminants, keeping the rest of the oil in the pan fairly clean.
I'm a fram user...but only toughgaurd. Do you have a photo of that taken apart?
I will not get the original orange filter from fram simply because of how light weight it feels. But the weight of the toughgard and honda felt quite similar. Although i realize that's no good way to compare filter quality, but its all i could do!
What's so special about the oil honda uses? I read it somewhere else to but yea, searched and I can't remember what thread it was a part of or if it was even on this site lol.
Honda says 600mile break in period though so iono. I was a little worried about oil change at 2k but I know some of the guys here did it sooner and went the same route with synt. right away.
One thing I was surprised not to see were any shavings in the oil from stuff wearing in though.
That Honda A01 filter looks good, is the one that comes from the factory. My local dealer could only supply the A02 filter, made in Canada and rumored to be by Fram.
That "magic" break-in oil has molybdenum in it, and Honda has repeatedly said NOT to change it until at least 5k, so why do it?
I'm not saying what you did is wrong or going to kill your car, but it seems like an unnecessary risk. At the very least it could void your warranty if they find out (which they won't, but that's not the point).
And they could find out if you document your actions, and the computer knows when you reset the oil life meter etc.
I've heard good things about Purolator filters also, but I've never used one. I might give them a try if they're cheaper and easy to find.
As far as changing the oil too early, all I've heard through word of mouth is that there's some kind of "stuff" that's supposed to be broken down within the first 5000 miles, so that's why we're not supposed to touch it
lol I suck at life then :P I even wrote it down :/ lawl. I'll just tear that page outa that log sheet they give you lol. I was never told to wait until a magic 5k mark either. Just was told to change it 3kish or so each time. Granted if you look in the manual it says to wait until the oil ind. says 15% about I think. Just was never informed I guess about it. I knew there was "special" stuff, that moly in there but didn't know honda recommended at set time for it to be there.
