Differential?
Old Aug 7, 2019 | 09:54 AM
Farrago's Avatar
Differential?
Does this Fit have a differential? If so, how often should the fluid be swapped out?
Or is it part of the tranny?
Old Aug 7, 2019 | 10:13 AM
silverrose12's Avatar
Old Aug 7, 2019 | 11:48 AM
petelite's Avatar
It is part of the transmission, as in every front wheel drive vehicle.
Old Aug 7, 2019 | 12:37 PM
USDM's Avatar
Old Aug 7, 2019 | 12:43 PM
Farrago's Avatar
Talking
Thank you all for helping me to continue my ever evolving understanding of automobiles.
Old Aug 9, 2019 | 11:35 AM
doctor J's Avatar
What is important, it shares the same compartment with transmission, so there is no separate drain and fill plug for it
On FWD (A/T only) Toyotas from 80's and 90's the differential compartment was isolated from transmission portion (but used same ATF DIII fluid); there are 2 drain plugs on the bottom: one on the pan, one under the final gear.
The differential fill plug was hidden form incompetent mechanic and was facing the firewall. So these big specialists with a little brain (not willing to consult manual before proceeding) drained both compartments but filled up only transmission portion (via dipstick); you can imagine what was expected next:
Grenaded differential
The issue is aggravated because no one bother to measure amount of drained fluid (in which case the technician would notice that they drained far more than needed to be put back) !
Sorry for Off-topic!
JerryHughes
Jul 13, 2019 11:09 AM
JerryHughes
Apr 10, 2019 11:33 AM
mandym22
Dec 18, 2014 01:11 PM
modfit669
Jan 4, 2010 07:14 PM
Kofi Anim-Appiah
Aug 6, 2005 04:43 PM
