Modified Honda Fit for better performance
Old Dec 23, 2020 | 11:25 PM
fightingraven520's Avatar
Lightbulb Modified Honda Fit for better performance
Hi guys. I've just read a post relating to modifying the Honda Fit that can make your Honda hatch more powerful by swap engines.
Swapping out your stock L-series engine with something more powerful is better than just hitting the turbo.
As to what engines are optimal for Fit models, there are the D16 or D17 engines used for Integras and Civics. You can also find the engines of the Honda B-series. These are the most common engines that have been switched for Honda Fit, and each of them has a lot of aftermarket performance parts available.
However, to make the most of your swap, it's advisable to get sport headers, a larger radiator, and an improved exhaust.
The larger radiator will have more optimal cooling while the better headers will boost exhaust and intake gas flow. Eventually, a strong exhaust will provide the engine with a quicker way to expel exhaust gases.
If you haven't swapped your Fit's L-series engine, for the 2004-2007 Fit, we suggest HotPipes Headers HP-HND00 for headers. On the other hand, the HotPipes HP-HND006 is suitable for the 2008-2013 Fit, while the HND008 is good for the 2014-2020 Fit.
Is there anyone tried modifying your Honda Fit this way yet, does it work for you ?
Old Dec 24, 2020 | 09:32 AM
NWCH's Avatar
B series does not bolt in. Nor is it the correct generation of engine for the Fit.
You must be very new to the Honda scene all together if you posting this bad information.
Old Dec 24, 2020 | 09:33 AM
NWCH's Avatar
You can modify any car to have more power. And you can swap engines in any car also. Not sure what the new news is here.
Old Dec 24, 2020 | 02:03 PM
GrE8_Fit's Avatar
L series motors go this way --->
B series motors go this way <---
Jim Bow
Sep 27, 2015 03:43 PM
phenoyz
May 17, 2015 01:37 PM
magdalena
Aug 17, 2012 04:49 PM
HONDAMATIC
Oct 13, 2009 02:46 AM
Stormtrooper
Jul 29, 2009 05:49 PM
