Dynamat vs Siless vs Made In China
Old Mar 2, 2023 | 01:57 AM
spotnz's Avatar
hi,
I've just finished sound proofing all 4 doors of my Fit. And have some observations that might be helpful.
NB My opinions expressed below are from my very own personal experiences of using Dynamat, Siless & a similar product Made In China.
Dynamat was the most expensive of the 3. It was also the hardest to install. Mostly because of it's ability to stick to anything & everything. This includes it's own backing paper . Which made it very difficult to use in temperatures around 20 celsius. I am very disappointed that in this age of hi-tech, the manufacturer doesn't use a better backing. It is also the softest of the 3 products. Dynamat usually only partly separated from it’s backing paper whenever I tried . Which made using larger or longer pieces challenging.
Siless & Made In China are in my experience are about equal. In both usability & quality. Both can easily be separated from their backing paper, cut to size & installed, with the same roller. They are both harder than Dynamat, yet still pliable enough to fit around sharp corners. Because I bought Made In China locally, it cost about the same as importing Siless, without any associated delivery delays. Noting that I live in New Zealand. I ordered Siless from Amazon Australia, which are currently offering free shipping for every purchase over $60. Interestingly ordering from amazon.com.AU, meant that this order was shipped from the USA. I had to wait well over a week for the order to be dispatched. After which it only took another week to arrive.
Whilst I can’t comment on Dynamat’s soundproofing properties. Based on my highly un-scientific testing, Siless & Made In China both seem almost identical, to my ears. I used Made In China on the rear doors & Siless on the front doors. Covering the inside of the door skin & the metal panel, under the door card. Both door cards also received some extra soundproofing material.
Old Apr 25, 2023 | 11:23 PM
chedd7's Avatar
Good info, thanks for the writeup
Old Apr 27, 2023 | 12:46 PM
jonshonda's Avatar
Interesting that the most important trait for the sound deadening isn't in question, it's the backing paper? I used dynomat last year w/o issue.
Just to clarify that you aren't sound proofing with this material, you are mass loading and sound deadening.
hoimingbeacon
Jan 13, 2018 08:37 AM
smeister
Nov 19, 2010 04:12 PM
KiNgKuRnG
Mar 26, 2010 02:28 PM
kelly
Nov 26, 2008 03:00 AM
Frank Boettcher
Aug 9, 2005 10:48 AM
