Windshield pump issues
Old Nov 5, 2023 | 03:10 PM
Palinadi's Avatar
I can't figure this issue out? My windshield fluid is not spraying. I don't hear the whirring you're supposed to hear. Neither front or rear
I've checked the nozzle it is not clogged.
ive emptied the tank and made sure to refill
The fuses are not blown
there are no leaks and no holes in the tubes
I replaced the pump and tried the whole battery test, it is getting the adequate volts it is supposed to.
we manually blew into the tube and the smallest amount of fluid came out both the front and rear. I did not hear a whirring.
but when we reconnect it, it doesn't work.
it is not cold or freezing so it can't be temp.
Is there something I have not tried? I've been on other forums, looked through here can't find anything and I've watched everything I can possibly find on YY.
Thank you in advance.
Old Nov 5, 2023 | 04:13 PM
Chitown Fit's Avatar
Windshield Pump.
Sounds like your windshield wiper pump is dead.
Old Nov 5, 2023 | 04:31 PM
Action Jackson's Avatar
Maybe the control stock and/or the MICU it's connected to is the issue? Is there a way to manually supply a signal to the new pump to see if it works?
Old Nov 12, 2023 | 05:57 AM
mobby_6kl's Avatar
Weird that both stopped working at the same time. It doesn't really make sense for both pumps or both switches to fail at the same time.
You could test the pumps with a regular power supply (or a 12v battery I suppose)
Have you measured if it's getting power at the conenctor when you turn the switch? My only guess is that they have a common ground and maybe it's bad? That would explain why neighter pump works even if you replace them.
albertaFIT
Mar 6, 2015 06:23 PM
EchoDmk
Nov 20, 2014 11:57 AM
msoulier
Feb 1, 2014 10:59 PM
littleblackcar
Nov 4, 2011 09:03 PM
Chazzlee
Jan 12, 2010 04:54 AM
