Honda Fit screeching sound at startup solved
If you are hearing a loud screeching sound
only during a cold and/or overnight startup, I found the fix.
It’s a weak battery. Replace your battery and it will fix the screeching sound during cold/overnight startup.
When you crank the ignition, the starter motor extends a gear mechanism that spins the flywheel. Once the engine is started, the starter motor will retract this gear mechanism. If the battery is weak, there is not enough power going to the starter to retract the gear mechanism fast enough, which causes the gear to grind with the flywheel and make the screeching sound.
This usually happens during cold, overnight starts. The screeching sound will go away if you drive around, stop, then start the car again because the battery has gained some charge from driving around.
This is a common issue on Honda Fits because our OEM type battery has low CCA or Cold Cranking Amps. Over time, the battery gets weak without warning and you will start hearing the screeching sound at startup.
I hope this helps anyone with this issue.
Could it also affect electric power steering?
I have the screech. Goes away if i rev the engine. Also noticed that the electric power steering seems not to be working at start up. The wheel will be stiff on start up but then gets better after warming up. I bet they’re connected. Will let you know after replacing battery.
staccyyh
Oct 23, 2019 08:12 AM
GinoLicious
Jan 12, 2014 02:12 PM
