Output shaft bearing.
Old Nov 4, 2024 | 09:19 PM
jbbuilt's Avatar
Leftside Axle is loose going into the automatic gd3. Even with all the play ther are no leaks.
Anybody ever dismantle the tranny and know how it is mounted inside?
Old Nov 9, 2024 | 03:17 AM
2015LXFIT's Avatar
Press fit ball bearing assy. with spacer and possible shim. Normally we "tap them out" after removing the seal, then using a socket from the outside in on the inner race/bearing cups. Sometimes they come out on the shaft, in which a puller and appropriate thickness metal disc is used. Good luck.
Old Nov 9, 2024 | 05:25 AM
jbbuilt's Avatar
A picture is worth a thousand words..lol. Thanks for the reply. This will be a winter project and just in case i will find a junked tranny to practice on. I may get lucky and find one with low kms on it. I already have a spare motor with only 40 k on it. Thanks again.
Old Nov 10, 2024 | 11:49 AM
Mister Coffee's Avatar
@2015LXFIT Nicely done, sir.
@jbbuilt Good luck. I don't look forward to having to do that kind of job when my time comes.
jonesym33
Jun 30, 2024 09:07 PM
ruby2009
Apr 24, 2021 03:01 PM
Kyle Van Dyk
Dec 11, 2020 09:42 PM
doctor J
Dec 25, 2018 07:41 AM
Nvillegas
Mar 31, 2013 12:58 AM
