Bearing for an idler roller
Old Dec 21, 2018 | 12:10 PM
doctor J's Avatar
I've scored a used roller with bearing NSK 6203-DUL1B with some bearing noise. So I pressed bearing out and pulled the seals:
Old original bearing (left) with black dusty grease; KBC replacement bearing on the right (overfilled with grease)
The original bearing contained some black grease mixed with very fine dust (source of the noise) I could not find specks for it (maximum RPM and dynamic load limits)
So far I've found 2 replacement bearings:
One is Korean made KBC
Dynamic load, lbs 2,100
Maximum Speed 12,000 rpm
Lubricant Grease (unspecified)
Temperature Range -20° to 230° F
ABEC Rating ABEC-1
And second one is SKF (Made in Argentina):
  • Dynamic Load Capacity2,200 lb.
  • Max. RPM24000
  • Temp. Range-40 Degrees to 212 Degrees F
  • Lubrication MT47 Grease
  • Industry Number 6203 2RS JE
  • ABEC Rating ABEC-1
Don't cry for me Argentina
This bearing has better designed seal lip which will prevent dust from getting in so I used SKF
Old Dec 24, 2018 | 05:13 PM
MTLian's Avatar
What's idler roller? Is it the idler pulley bearing for the serpentine belt? If so I'm very much interested. I changed the transmission input shaft bearing with a honda bearing and I regret it a bit. It's a little noisy again. I wished I'd used a higher quality bearing than the OEM because it seems they are prone to failure.
How much is the bearing? I believe the replacement idler for serpentine from Gates is like 15$.
Old Dec 25, 2018 | 07:41 AM
doctor J's Avatar
Yes this is an idler roller for the belt. The bearing is about $10 from Grainger (bough it a while ago). The seal design of original bearing was not capable of stopping the very fine dust from getting inside on the donor car; I'm expecting the same about my car as well.
Vash
Sep 5, 2016 10:35 PM
MTLian
Sep 7, 2014 01:36 PM
Nvillegas
Mar 31, 2013 12:58 AM
Piscator
Mar 8, 2013 08:40 PM
beangrower
Jan 12, 2012 02:01 AM
