Remove spare tire & jack?
Old Nov 16, 2007 | 12:11 PM
cspan37421's Avatar
What about jumper cables? Do most folks still carry those? I've been driving for 24 years and I don't think I've ever needed them. Well, once, a friend's car had a dead battery. But I'd like to not have them in the trunk. Ideally, I'd like to store all the emergency stuff I need down in the spare tire wheel well. The ones I've got are bulky and heavy gauge.
Note, I got the wheel locks, and the wheel lock key fell right out of the little vinyl satchel that the lug nut wrench fits in. It ended up hiding under one of the floormats - took me awhile to find it. They give you a special zip tie that you can use to secure it to the lug nut wrench, but it can't be used as secured, so I left it loose. Watch out, without that thing, you can't change a flat!
Old Nov 18, 2007 | 12:01 PM
F-IT!!!'s Avatar
it does help a little I use to have my 98 civic 2dr and pretty much gutted out the interior and trunk and let my friend drive the car and he noticed how the car felt like it was light and moved around a lot easier he said. fuel wells I didn't really noticed that much because I was always revving the civic high heheh but maybe if I didn't rev high I would prolly saved more gas hehhe so weight reduction does help. and ohs yeah about that post about pumping gas slowly into your car saves more gas that shit does work i did save more and the tank was full 11 gallons usually when the gas light comes on and pump fast it stops at 9 but when pumped slowly its 11 when light comes on. and I only pump 93 in my car go with the good SHIT
Originally Posted by NMG
Honestly, I be shocked if you saw any measurable gain in fuel economy that could be attributed to getting rid of the spare and jack. I just can't see that much less weight having any impact when you consider the total weight of the car, etc.
Old Nov 18, 2007 | 01:26 PM
J_L's Avatar
J_L
Originally Posted by Meterman
"dont put fixaflat in a tpms rim/ tire youll screw it up"
Mmkay, but the 2009 doesn't have a spare tire.
From
Honda Worldwide | October 18, 2007 "Honda to Begin Sales of the All-New Fit in Japan"
"An emergency tire repair kit is provided instead of a spare tire"
So Will the 2009 have tire pressure monitoring?
They will in the US, the feds have decreed that all new cars after Sept '07 will be so equipped.
Old Mar 13, 2008 | 12:09 PM
JPfit's Avatar
Originally Posted by t-bone
According to Murphy's law:
As soon as you take out your spare, you will end up getting a flat tire that a fix-a-flat can't fix.
J/K
What's ironic is that some of the earlier W211 E55's came with the fix-a-flat and many people were going to the dealer to buy a spare to put in the trunk instead.
Yep...I've done that before.. I was delivering pizzas in an Accord when I was a kid,.. I backed up into the jagged corner edge of a broken parking curb, and blew the tire.. I kept two cans of Fix-A-Flat in my car.. shook them up for at least a minute, and watched both of those cans of that goop spill out of an approx. 1" hole in my tire.. which really sucked..
Well, I do have AAA, and some more cans of that stuff, however.. that's not always enough when you work on deadlines..(I do photojournalism and commercial photography)..when a tire swap with that mini jack can be done in 10 minutes tops.. Waiting for a tow truck, IF he needs to drive me to a tire shop, and waiting for them to fix that can take all day!
...keeping my fingers crossed doesn't always work either..
JP
Old Mar 13, 2008 | 12:11 PM
JPfit's Avatar
that takes care of that..
JP
Old Mar 13, 2008 | 01:33 PM
wademunkey's Avatar
I believe that BMW is putting spares in now since the RunFlats were so rough until they redesigned the suspensions to accomodate.
Andrew
Old Mar 13, 2008 | 02:14 PM
ellenoc's Avatar
It's funny how different people are. I've already had a flat on my Fit. It was less than 2 months old. Sunday night, out in the boonies, I had to drive over 100 miles on the donut. Manual says must drive less than 50 mph on that thing. It was a tedious, scary ride home. Scary because other vehicles come zooming up at you from behind when you're going so slow. So before my next weekend trip to the Colorado wilds, I'm going to have a real spare to take. The extra weight is irrelevant. I'm not willing to get killed because car companies save a few bucks with that stupid donut.
Old Mar 13, 2008 | 02:31 PM
tonyd3773's Avatar
Smile
I do not understand why the tiny spare? All of my EURO cars prior ALL had full size spares......I think this need to be re-thought by ALL major car companies!!!
FULL SIZE SPARES FTW!!!!
Old Mar 13, 2008 | 02:54 PM
i dont mind the donut. it's not like i get a flat so often... i bet most
of you dont even check the tire pressure on your donuts.
i fill mine to 60psi near winter time and let the air out down to 60psi
come spring.
my cooper-s runs regular tires and dont even have a spare. i have
a can of fix-a-flat, 12v air compressor, and a celphone.
Old Mar 13, 2008 | 07:38 PM
airborne200208's Avatar
I do in my Ridgeline. As well as a tow strap.
I took the spare out of my 97 Accord and 94 del Sol, and It did nothing. I don't think i'm going to do it on any other cars I own after what happened Monday night when I hit a pothole in my Ridgeline:
Fix-a-flat has nothing on a bent wheel.
Old Mar 13, 2008 | 07:46 PM
tonyd3773's Avatar
Smile
come spring.
U should mind the donut....it's dangerous.
A full size spare in every car should be a law.....IMO.
Old Mar 14, 2008 | 08:09 PM
  #32
Mark16q's Avatar
I used to take the spare out of my S2000 on the track, and it definitely changed the handling for better.But don't think the car ran any faster due to the weight reduction. And the spare was used to hold down the ez-up from the desert winds.
My Elise doesn't have a spare, nor is there room for one. Just a can of fixaflat and I carry a package of plugs. Fingers crossed on long drives...knock on wood.
If space was an issue, I'd take the Fit spare out, but so far plenty of room for my purposes.
mg
Old Mar 14, 2008 | 08:16 PM
  #33
jtsimaras's Avatar
That must of being some SERIOUS &SS pothole
Old Mar 14, 2008 | 08:50 PM
  #34
Fit_US's Avatar
When I was driving crap cars I would go to the junk yard to buy a full size rim. Of course they wanted to charge for the rubber but I would tell them to take the tire off. I would have a full size tire for the cost of a junkyard rim. With the Fit I won't bother since there's a tire store every 10 miles and I'm too lazy to go hunting for a rim with good rubber.
Old Mar 15, 2008 | 01:03 PM
  #35
NEK FIT's Avatar
Question Big consideration
Originally Posted by spreadhead
If I bought a car without a spare, the first thing I would do would be to get one for it.
Amen to that.
I have a new Fit on order. One of the reasons I opted for an '08, rather than waiting for the new generation '09, is that this year's model still has a spare. I think Honda is making a big mistake in going the no-spare route to squeeze a few more square inches of cargo space into what is already a very efficient design. If you live in a rural area (as I do) or travel through rural areas (as most drivers do), you may find yourself many miles from a station where you can get a new tire or have a flat fixed. And a lot of stations aren't prepared to deal with run flat tires. I wonder if Honda thinks everybody lives in a city.
Old Mar 21, 2008 | 07:05 AM
  #36
storm88000's Avatar
Frequent FitFreak Poster
Yeah seriously, it looks more like he hit a sinkhole rather than a pothole..
Old Mar 21, 2008 | 07:38 AM
  #37
fittmann's Avatar
Originally Posted by Steeldog
I thought I read somewhere on this forum that there is no spare in the '08 Fit to begin with.
Hopefully that isn't the case. Any of us can run over something (like a bent piece of sheet metal) that cuts into the tire in such a way as to make it unusable and impossible to fix.
With only 879 miles on my car, I hit a piece of iron pipe, which not only put an approximately 2' hole in the tire, it also put a 1.5 gash into the wheel rim as well!! "Fix-A-Flat" in this instance would have been totally useless; even accounting for first time use of the jack, I was on my way within 20 minutes!
'07 VBP Sport 5MT
Old Mar 21, 2008 | 10:22 AM
  #38
storm88000's Avatar
Both the '07 and '08 Fits do indeed come with a spare..
Old Mar 21, 2008 | 10:47 AM
  #39
yeamans17's Avatar
Heed the warning of no Fix-A-Flat into your tpms if you have it, you'll end up buying a new tpms for that wheel and the dealership will not warranty this since its a stupid mistake. Anyone who works in and around tires hates that shit.
Old Mar 22, 2008 | 11:57 PM
  #40
bwb's Avatar
bwb
Temporary fix only: Fix-a-flat or tire plugs?
As a related question: For temporary fixes only, assuming one also has a spare and/or AAA, would fix-a-flat or tire plugs be preferable?
I've read a lot of posts about both - but most posts focus on using them as permanent fixes (which of course you shouldn't do). I'm assuming I'd use plugs/fix-a-flat when a quick fix is needed (short distance to meeting at work) and/or spending time putting on a spare is dangerous (freeway). I know plugs are fairly quick instead of spares, but the fit is fairly low -- would plugs really be easy to put on without removing the wheel or jacking up the car?
I also have emergency triangle, foot pump, and tire gauge in the spare tire well. If it matters, I'm in california right now, but will be moving to michigan within the next few months (where fix-a-flat could freeze).
