2009 Fit - Gas tank size > 10.6 gallons?
Old Nov 12, 2008 | 07:53 PM
  #41
zukered's Avatar
^ There's a downside to filling up when your tank's not near empty: your mileage calculations can be significantly off if the pump shuts off even a second early or late. I filled up once when my tank was 3/4 full, and my calculated mileage was the second-worst I'd ever gotten. If the pump had shut off just half a litre earlier, it would have put the figure above my 5-tank average at the time.
Old Nov 15, 2008 | 08:41 PM
  #42
reako's Avatar
Is the OP "topping off" the gas tank? Squeezing and releasing the pump lever after it automatically stops fueling? This can result in you paying for gasoline that is fed back into the station’s tank because your gas tank IS full. The gas station pumps are equipped with vapor recovery systems that feed back gas vapors into their tanks to prevent the vapors from escaping into the air.
Old Nov 16, 2008 | 07:36 PM
  #43
potownfit's Avatar
I let my '09 run for about 35 miles after the light came on. When I filled it the pump clicked off at 10.4 Gals, I was then able to put in a bit more for a total of 11.5 gals.
I'll probably do the same thing again in a few tanks to see if this repeats itself.
Old Nov 17, 2008 | 02:13 PM
  #44
Pacedog's Avatar
Originally Posted by TitePhit
Hey bro. We just got our '09 fit sport. I ran the tank EMPTY. I know your not supposed to do that, but we were on a road trip and almost to a preferred gas station. Anyway, it only took 9.8 gallons. So, your over 11 gallons seems like the pump may have been off or something. I don't know...just thought I'd share my story that happened just tonight.
Nah he is right...I've put 11.9 in mine as well.
Old Nov 17, 2008 | 02:16 PM
  #45
Pacedog's Avatar
That's crap because keep filling it and see if it doesn't spill back out onto the ground, the side of your car, and all over your hand.
I fill to the first click, shake the car and pause a few seconds and then continue. From the first click of the pump to I get her topped off I have put in another 1.7 to 2 gallons.
Old Nov 20, 2008 | 12:16 AM
  #46
reako's Avatar
No, thanks. I'll let the pump operate as designed, and fill my fuel tank to levels intended by the manufacturer. You, shake your car when you fill up??
Old Nov 20, 2008 | 12:51 AM
  #47
CBX's Avatar
CBX
Thankfully, not all States require those California-style vapor recovery nozzles. They sure are a nuisance when filling a bike (the nozzles, not Californians)!
I just might give the Fit a little shake next fillup.
cavernap
Aug 13, 2018 02:41 AM
fitchet
Dec 23, 2017 05:48 PM
Scott Man
May 28, 2008 10:55 AM
randomracer
Dec 17, 2007 11:15 PM
chibitul
Sep 5, 2005 12:33 AM
