Fit stutter/hiccup problem
Old Apr 21, 2009 | 05:50 AM
Rob22315's Avatar
Originally Posted by macbuddy
Okay Guys,
I went from .040" down to .035", and yeah, I know that Honda specifies the range to be within .042-.051"... but hey, it wouldn't hurt to give it a try!
Guess what? It worked! Misfire above idle has disappeared so far (I do detect minor misfiring at idle, but only with the A/C on). Anyway, the positive for now is that I can drive my Fit like I used to.
This isolates the problem down to the spark generation and distribution system which is what we've suspected for a while. Gap isn't the source of the problem. Since you've gone below spec, some other component isn't performing properly, either a coil pack, or the trigger for the coil pack (ECU? or wire). I'd regap the plugs to spec, then get one new coil pack and begin swapping it onto the plugs until I found the bad pack(s). It could also be a loose or low power feed to the packs.
I'm sticking with the bad coil pack theory. There appears to be enough power to generate a little bit of a spark and the triggering mechanism works if the problem goes away when the plug gap is small. One or more of the coil packs just isn't recharging/generating enough power to jump the gap every time.
Old Apr 24, 2009 | 06:35 PM
macbuddy's Avatar
Spark Plug update...
For the record, I've been driving around with the original plugs (with 71K on them) gapped at .035" for the past few days, and the Fit has been running fine. My latest tank of gas showed that the mpg is normal, so I didn't experience any noticeable loss due to using a smaller gap.
UPS delivered manxman's extra set of plugs on Monday, but I didn't have a chance to install them until an hour ago. BTW, the plugs that manxman sent were made by NGK, my car shipped with Denso. Anyway, I gapped the fresh set at .045". installed them, and gave them a test run. I just got back from a ~20 mile, ride and they seem to work great! The Fit now idles without "hiccups" even with the A/C on!
I know this prolly won't work for all of the guys posting on this thread, but I just wanted to let you guys know that changing the plugs helped in my situation.
I just talked to Sam, at my Honda service department, and told him about the spark plug change. He said that in normal driving conditions, the plugs should last up to 105K. He added that his service manual states that under "severe conditions," plugs may need changing before the 100K. He commented that if one consistently runs the rpm at twice the rate of the normal driver, that it only makes sense those plugs are going to fail sooner (than the 100K). Hmm...makes sense to me!
-macbuddy-
PS-thanks for the plugs manxman!
Old Feb 10, 2010 | 10:59 AM
docjim2's Avatar
got the same reaction
Originally Posted by Jaime
My 08 Fit Sport auto started to stutter/hiccup when the engine was warmed up and the throttle was held steady at one speed, any speed as long as it was a consistent speed. I took it in to WILLIAMSON HONDA in Lincoln NE and they said a connector was loose because I disconnected it several month ago, the EGR or something.Well that is not true. I did disconnect it when I put a Spoon sock over it but I am sure I connected it again. Why would it take 3-4 month and 2 thousand miles to act up if I did indeed not get the connectors pushed togher all the way? (By the way the Spoon sock is a no no as it causes overheating and it must come off now. Oh, wait they didn't take it off) I smelled Rat and told them so. $170.00 to push two ends of a connector together. The chicken sh*&s decided they did not like me telling them I was getting advice from my lawer so they decided not to charge me but to tell me in a loud voice out in the open near the waiting room full of people (with about 6 service workers standing there ,) that I was not to come back to their dealership. WILLIAMSON HONDA in Lincoln NE is a bunch of good old boys that do what they want because they are the only Honda dealer in town!! I say all Fit owners should write them a letter. Not that they would care.
Some Honda 'dealerships' love to push the problems under the counter! Happened to me... I was told that if I was contrite and went back to the dealer and got on my knees and apologized I could bring my car back.... Huh??
Old Feb 10, 2010 | 11:06 AM
docjim2's Avatar
Still have the problem. Honda has opened two (2) complaints on this prob with me: deleted the first from their database.... but they still had my name there. Is this just ignoring to their own detriment??
Honda listen up: look at what happened to Toyota when they just did the bean counting thing and pushed their probs under the rug??!!
I would not own a car that had missing/stuttering/cylinder misfiring at all! Now if I bring in my Fit for a trade and the dealer finds out then the car is not worth anything??
By now Honda has lost many customers because of problems like these. There have been recalls but all I get in the mail are coupons for service at a dealership I was banned from. Go figure.
mkht78
37
Jan 19, 2011 12:39 PM
tecknical
Sep 21, 2008 10:31 AM
FaceYogurt
Mar 18, 2008 11:47 PM
kentris
Dec 21, 2006 05:17 PM
blackgd3
Jun 29, 2006 02:57 PM
