how do you know when it is time to change brake pads
Old Jul 11, 2009 | 07:57 PM
derekparker's Avatar
I have a 2007 honda fit with 42000 miles. how do i know when it is time to change brrake pads?
Old Jul 11, 2009 | 10:15 PM
warren561's Avatar
Take the front wheels off and inspect the pads (in the calipers) with a flashlight.
Anything less than 1/8" should be replaced IMHO.
Old Jul 11, 2009 | 11:10 PM
is it true that the honda brake pads make a screeching sound when it is time to replace?
Old Jul 12, 2009 | 12:04 AM
polaski's Avatar
On most Hondas when it (inside pad usually) gets down to the indicator it goes SQUEEEEEEE every time you back up. That's assuming your caliper slides don't bind up, that both wear evenly, etc. Best to keep an eye on them every time you rotate the tires (every 6k for me).
Old Jul 12, 2009 | 10:44 AM
Firebat666's Avatar
when you can't stop and start crashing into things its time to get them replaced lol JK! you will hear screeching, but i would just go for visual confirmation once in a while....
Old Jul 12, 2009 | 07:10 PM
mahout's Avatar
This is the best advice here. The 1/8" refers to the thickness of the pads, not including the backplate. In other words the non-metal pad, not the metal backplate.
It is a job you can do yourself if you get a knowledgeable friend.
Old Jul 15, 2009 | 02:23 PM
r1concepts's Avatar
some brake pads have wear indicators on the pads which makes a screeching noise when needed to change. +2 on checking the pads yourself.
Old Jul 15, 2009 | 02:32 PM
TurboManGT's Avatar
Yeah my old Civic would screech like a bitch lol
It was annoying
Old Jul 15, 2009 | 03:13 PM
i too just take my flash light and a telescoping mirror tool to check thickness. i dont have to remove the wheels.
CrystalFiveMT
Aug 21, 2015 04:49 PM
SevereService
May 18, 2014 12:29 PM
harlen
Apr 24, 2011 05:42 PM
Marrk
Mar 2, 2011 03:09 PM
TWGE08
Apr 5, 2010 11:20 AM
