Tire size and ABS
Old May 9, 2006 | 10:26 AM
fatoil's Avatar
Unhappy Tire size and ABS
Hi,
My FIT LX came with 175/65/R14 tires and I want to upgrade to 195/55/R15. According to the user manual, it will affect the function of ABS if the size is different from the original specification. I know 195/55/R15 is the size of the sport model. Is there any difference between the settings of LX & Sport model? Anybody can help?
Fatoil
Old May 9, 2006 | 02:25 PM
dougiepants's Avatar
Avid FitFreak Poster
Dont worry every car's users manual states that... Just upgrade and you should be fine...
Old May 9, 2006 | 02:48 PM
wyy183's Avatar
The size that you have is not what is important - what is important is that all the tires that you have are the same size. You want all the wheels spinning at the same rate.
Old May 9, 2006 | 03:53 PM
fatoil's Avatar
Thanks for your information, however 195/55/R15 is bigger than 175/65/R14 in circumference. Will the difference cause the error of speedometer and odometer? This is my concern.
Old May 9, 2006 | 04:21 PM
wyy183's Avatar
The difference is only 2%. At 50 mph, that's only 1 mph difference.
Old Dec 25, 2014 | 10:21 AM
mahout's Avatar
Its the difference in rotating rate that activates the ASC. And f they don't spin differently inside to outside of a turn your turning will be a problem. It is important that the inside and outside tires be the same diameter. Not the wheels but the tires.
Pacemaker
Jul 6, 2018 06:58 AM
littleblackcar
Sep 4, 2013 08:23 PM
Darren Lund
May 18, 2012 01:54 PM
hoss10
Mar 31, 2011 09:28 AM
Drewnickd
Feb 4, 2011 04:09 PM
