WHAT do you do to improve your gas mileage?
Old Apr 24, 2010 | 02:31 AM
  #41
stockrex's Avatar
I would stay clear of K&N, more flow = less filtration. with K&N a UOA will reveal elevated Silicon count, will wear out your cylinder walls. oil from filter will foul sensors.
See link for pressure drop between clean and dirty filter, best results from modifying the intake tubing rather than messing with the filter.
Browser Warning
MPG: I found that some gas stations give less mpg compared to others, usually anything with ethanol will yield less mpg.
Old Apr 24, 2010 | 02:42 AM
  #42
Vash's Avatar
Browser Warning
MPG: I found that some gas stations give less mpg compared to others, usually anything with ethanol will yield mpg.
i agree with this guy about the K&n comment.
from my experience i think keeping a high tire pressure has been the best for mpg improvement. like i would more then double my gas mileages by just keeping my tires well inflated
Old Apr 24, 2010 | 03:19 AM
  #43
crash001's Avatar
Shell gets me 20 miles more per tank
Old May 3, 2010 | 01:04 PM
  #44
Black01's Avatar
I drive slow(between 50-60mph), slow acceleration, and slow deceleration.
Old May 16, 2010 | 01:11 PM
  #45
cadee's Avatar
don't change up your driving style, it doesn't seem like ur ricing around or anything. how many miles on your 08? Changing up your spark plugs could be a good start to getting better MPG.
Old Jun 16, 2010 | 01:12 PM
  #46
rjs398's Avatar
Unless you are driving on very smooth surfaces a highly inflated tire creates more rolling resistance..... The radial plied sidewalls are supposed to flex to improve fuel mileage and prevent the belted tread from rolling under or lifting off of the road surface in turns, over inflation prevents this from happening and so the radials work no differently than bias ply tires
Old Jun 16, 2010 | 01:30 PM
  #47
Krimson_Cardnal's Avatar
TOP TIER FUEL
Do a google on it. This is what all fuel companies should be doing for the customer's and the environment. Shell is a partner in this. Most difficult to find any where in the North East. Big boy distribution networks - not in our interests.
It is for real. I gained 10% avg MPG in a 12yr old Cadillac. We need to ask, "Why not.".
K_C_
Old Aug 5, 2011 | 02:34 AM
  #48
rookie33333's Avatar
2008 Honda Fit Sport
I've noticed that when I'm driving interstate that when I go the speed limit "75" my car tends to shift from 5th to 4th on every little incline in the road which I'm sure limits my gas mileage.....any way to prevent this or is there a different speed I could go that would get better mileage?
Old Aug 5, 2011 | 02:38 AM
  #49
BraytonAK's Avatar
More likely it's disengaging the torque converter than making full gear changes. The only thing you can try is to shift into Sport mode and manually try to get to 5th. You'll still notice the torque converter disengaging periodically, though.
Old Aug 5, 2011 | 08:43 AM
  #50
Texas Coyote's Avatar
There was a recent post by a guy that said his automatic transmission was doing the same but there was enough of an increase in torque from changing over to premium fuel that it was no longer down shifting on hills.
Old Aug 5, 2011 | 09:17 AM
  #51
555sexydrive's Avatar
No T_C why did you say that...the 244 guy will now be posting in this thread to keep repeating the same crap in every thread that mentions the word premium even if not talking about fuels. :P
Old Aug 5, 2011 | 09:24 AM
  #52
I drove like I always do (actually a bit more aggressively due to wanting to feel out the car) and I got 37 mpg on my first tank....how do you guys get less?
Old Aug 5, 2011 | 09:39 AM
  #53
I had forgotten all about him since I used the ignore function.. There is a major difference in telling a person how to address a problem with a solution and being a problem that ignoring is the only way to deal with.
Old Aug 5, 2011 | 09:49 AM
  #54
If you drive aggressively and want better fuel mileage, more octane.... I only got a couple more MPG than what you are getting but I was driving miles at a time at 90MPH and passing long lines of slow movers on 2 lane highways.. That was before the KWSC...
Old Sep 8, 2011 | 09:06 PM
  #55
Vesper Ignis's Avatar
My experience reflects that of the other comments on this thread. The two biggest gains to gas mileage I have see have been with driver modifications and tire inflation. My wife's average mpg with my fit is 35mpg and my average with regular driving habits is 40mpg. While hypermiling, I managed to get up to 54mpg.
I typically air my tires up to 4psi under max. I can tell when they start getting low because my mpg goes down. I have seen a lot of people saying that your tires wont last being aired up like that. The tire wear I have seen seems to be acceptable to me. At 120k total car miles (69k on the tires) I am down to 6/32" on my first replacement tires after replacing the OEM Dunlops at 51k.
'07 Base MT
Old Sep 9, 2011 | 02:42 AM
  #56
I do nothing to improve my FE. My average MPG to date is just a tad over 29mpg, which I'm ecstatic about being that the Tokyo area is not the most fun place to drive around everyday and my right foot only knows 555(go go go). Even the expressways are like parking lots often times and you pay for express service!
I keep my tires at about 220~230kPa(31.9~33.4psi). More than enough pressure being that the sidewalls on AD08's are super stiff.
Old Sep 12, 2011 | 04:25 AM
  #57
craigquakertown's Avatar
The A/T is great on hiway on mpg stop and go city not so great. I just took a trip from Chesapeake, Va. to Elizbethcity, NC. about 80 miles and it got great milage went down Rt 17 no stops at 60-70 mph and got great mpg. But the 24 miles from home to work with alot of lights the mpg is not that good. I read from others that the 5sp man. is better in city because of the gearing.
the ten gallon tank shows in city traffic but i still get pretty decent mileage if i just keep from flooring it from light to light
Old Sep 12, 2011 | 06:32 AM
  #58
BlackPearlFIT's Avatar
my strategy for the search for ultimate MPG's:
1. Enter on freeway
2. Get behind semi truck
3. Draft behind him and keep a steady foot on the gas pedal (use clutch when ever possible)
4. Watch MPG's go through the roof.
Old Sep 13, 2011 | 12:01 AM
  #59
Cordizzle4life's Avatar
Well. One of the best things to do for better mpg is to reduce weight. Although the Fit is indeed a VERY light car, it can be lighter. For instance, that bench seat in the back of the GD3's weighs at least 75 lbs. For me, I never had more than three people in the car at any given time, and the added cargo space is very welcomed, plus I noticed about a 3 mpg difference. So, if you don't have a ton of people in your car often, you can take that bench seat out and save on some weight.
Old Sep 13, 2011 | 12:26 AM
  #60
DiamondStarMonsters's Avatar
I put a mast and sail on my Fit. Also, I hired an illegal immigrant to provide pedal power to the back wheels.
