What Honda engine would you like to see in a Fit?
As I said in the "If you won the lottery" thread, Send the Fit out to Rad Rides by Troy in Il and have her fitted with an LS9 out of the CTS-V! RWD of course! That out to asuage my need for speed, and getting sideways in four out of five gears LOL
im not sure a short wheel based honda fit with rwd and about 400+hp is going to be alot of fun. youll likely spin out at even a hint of steering input.
i would like to swap a k24a (k20a head/cr-v block hybrid) with a ct or vortech or jackson racing compressor with a built bottom end and full head work with aggressive cams and timing. slap on a lsd with a stiff racing clutch and i think the setup can fly by most sports cars on the road.
could you imagine a fit with that distinctive STi rumble? oh the sex.
but as far as a honda engine? gotta rock a k20 with a little switch to it...rear mounted rwd. the fit is so front heavy because of the seating positions and the placement of the gas tank it would actually balance it out a bit and of course a suspension guru would be able to straighten out everything else...
But I like the way you think though.
Realistically I would love to see a B16B from Spoon ... +10k redline, and still has the light weight to power ratio, plus it is still FWD.
And if we going crazy with non-Honda Stuff I say WRC spec 4G63 from the early rally cars with anti-lag back fire... OOOOOooorrrr the V8 from a Ferrari 458, perhaps.. Hahaha
Cordizzle4life
Aug 14, 2019 10:21 PM
Midnightfit
13
Apr 21, 2008 09:46 PM
just stock will be fine 230hp ftw!
or a smaller version maybe?>>>>>>>>>>>>>>>>>>>>>>>>>>>
