Scan Gauge II or Ultra Gauge
Old Apr 24, 2011 | 11:35 PM
grant22's Avatar
I've been reading up on these two gauges on the forum, but have just seen on Ultra Gauge's site that they are selling them for $60 currently. This leads to my question,
Which one of these is better overall (not factoring in price)? If some of you think the Sacn Gauge is better, would you jump on the Ultra to save $100?
I'm looking to get one of these, but just not sure which one to get now.
THX
Old Apr 25, 2011 | 12:14 AM
Java^FiT's Avatar
i got the ultra and I dont regret it one bit! I think its a nicer display and has more configurability but im sure every one will have a beef on either one. personally in the end it was down to the price for me and for 60 i couldn't go wrong.
Old Apr 25, 2011 | 12:27 AM
clicq's Avatar
I have a Scangauge and just a warning, but the XGauge doesn't seem to work with the Fit -- apparently, it doesn't form addresses correctly for the CANLF protocol (see this thread for reference: XGauge Coding - Page 3 - CleanMPG Forums).
This isn't a huge issue, as all the built-in gauges work, but if you wanted to monitor things like short- and long-term fuel trims, you're out of luck with the scangauge.
On the plus side, the Scanguage is a bit smaller...
Personally, I'd probably get an Ultragauge if I was currently in the market.
Old Apr 25, 2011 | 12:49 AM
grant22's Avatar
Thanks guys. I'll order one in the morning.
One more question, has anyone here actually used one of these to diagnose and maybe repair something on their car (after it threw a code)? Although their ad says it will display codes, just wondering if it's practical with these.....
Old May 18, 2012 | 04:24 PM
DaveFL's Avatar
Ultraguage is not as easy to setup as SG, mainly to the fact it can monitor 50 items while showing 4-8 per page which has to be setup by user. I bought one for my mh but figured I would try it first on the Fit. I like it enough to say I will only transfer it out when we go on a long trip with the MH. It is too heavy for the supplied velcro to hold it, if direct sun can hit it. I found a spot but will have to modify my diy bracket to take the weight instead of the velcro self stick glue. I found it can be mounted above the steering column just below the odometer. _/---
Old May 18, 2012 | 05:32 PM
Goobers's Avatar
Why are you resurrecting old threads?
Old May 18, 2012 | 09:02 PM
Rampo's Avatar
On my GE I mounted the scangauge with velcro directly below the vent lever. I have it set to monitor water temp, voltage, miles to empty, and gallons remaining. I used it on my daughter's GD to read a CEL code but haven't had the opportunity to try it on my GE.
Old May 19, 2012 | 12:08 AM
DaveFL's Avatar
Came up when doing search, missed the old date, came up before the newer ones. Maybe moderators should close old ones if it offends you.
Old May 19, 2012 | 12:17 AM
Goobers's Avatar
And where did I mention I was offended?
I was asking because this was the second thread that you resurrected. The other one being about fuel pump in the 2nd gen section, also a year old since previous poster.
I assure you, if it offended me... I'd make that clear as day.
edit: my, aren't we snippy.
Old May 19, 2012 | 04:42 PM
fitted247's Avatar
From what I've read, saving the $$ and buying the Ultra seems to be the best bet.
Old May 21, 2012 | 10:04 AM
Virrdog's Avatar
Even disregarding the money, the Ultragauge has the better display... much better screen configurability... and can access up to 56 gauges with 6 button presses (or none at all with it's page scrolling ability).
It wins hands down to me.
Old May 21, 2012 | 10:05 AM
Java^FiT's Avatar
I've got a UG for sale if anyone is interested. PM me
Old May 25, 2012 | 12:53 AM
disruptor's Avatar
I got the Scangauge and love it. Personally dont know much about the Ultra.
Old Jul 6, 2012 | 10:31 PM
Dwalbert320's Avatar
I would like to purchase the Ultra Gauge for the following features. I would like some comments to help me decide my purchase. Thanks.
Outside air temp : does it work on our Fits?
throttle position : kinda fun to watch no?
Manifold air temp : when the engine is cold it's like the outside air temp right?
All the fuel level gauges: good to know what's going on in that tank.
KM/H : easier to set the cruise control to a digital read out than to a dial?
Any other fun things you like about it?
Am I dismissing the Scan Gauge too quickly?
Last edited by Dwalbert320; Jul 6, 2012 at 10:32 PM. Reason: Grammar. Sticky fingers
faxe
Jan 18, 2013 03:25 PM
NotraFit
Dec 26, 2008 09:03 AM
hkjazz
theljnet.com
Jan 2, 2008 12:34 PM
chibisak
Sep 29, 2007 07:15 AM
Jimmy101
Jul 7, 2006 10:40 PM
