towing a Fit
Old Aug 12, 2012 | 12:12 PM
gypsysuzy's Avatar
towing a Fit
I tow my 2010 Fit with my motorhome. I have had several instances this summer where the battery in my Fit goes dead. It seems to happen in a random pattern, no correlation between number of miles or anything else. Honda claims they have never heard of such a thing and yet I know two other Honda owners who have the same experience. Anyone out there know a solution?
Old Aug 12, 2012 | 04:28 PM
n9cv's Avatar
Have you considered charging the Fit battery from the towing vehicle while driving down the road. I do that to most anything I tow. There is a pin in the 7 pin trailer wiring harness reserved for that use.
Old Aug 12, 2012 | 08:23 PM
AC7880's Avatar
That is what I do as well. Circuit breaker on the motorhome end, and one on the tow car as well.
Originally Posted by n9cv
Have you considered charging the Fit battery from the towing vehicle while driving down the road. I do that to most anything I tow. There is a pin in the 7 pin trailer wiring harness reserved for the use.
Old Aug 12, 2012 | 11:49 PM
gypsysuzy's Avatar
Thanks! I'll be checking that out with the rv guy this week.
Old Aug 13, 2012 | 12:07 AM
n9cv's Avatar
If you are not powering anything heavy and only charging the battery, 12 gauge wire and two automatic reset circuit breakers (available from AutoZone) should do the trick. You can get them in blade type that plug into a normal large blade type fuse holder. I have a 45 only because I sometimes power a winch to drag cars on to my trailer and occasionally a 30 amp will trip. For battery charging a 30 amp never trips.
Old Sep 21, 2012 | 10:12 AM
JGHayes's Avatar
I am new to towing and am using the Invisibreak. It requires a connection from the RV to the Fit's battery to keep the battery charged for the breaking system. This will also eliminate having to pull the radio fuse, which I can barely get to to remove let alone see it well enough to replace. I am getting ready for my first extended trip and will let you know how it works.
bigisland
Jul 13, 2021 05:39 PM
naps1saps
Dec 13, 2017 02:19 AM
fRed
May 10, 2015 07:15 AM
FlaDan
Dec 31, 2009 08:13 AM
jhoprodie5
Mar 12, 2008 12:20 AM
