15x7-RPF-1 center cap
Old 12-03-2012, 10:36 PM
phenoyz's Avatar
does anybody know if this OEM center cap from a 04-05 civic Si
with part number: 44732-S9A-A00 fit into a Honda Fit GE with
15x7 rpf-1? or the CRV: 44732-SJC-A500
Good-win racing is selling the Helium center cap but i don't know if it will
look good or blend-in into the Ge Fit?
will these fit-in w/out no problems?http://www.ebay.com/itm/Honda-Accord...28b862&vxp=mtr
_
_
Old 12-03-2012, 11:40 PM
Hootie's Avatar
I'm not 100% sure but I believe I heard that the center caps from an Odyssey, Ridgeline, or (second gen) Pilot should work.
Old 01-10-2013, 01:02 AM
jt3944481's Avatar
I know FOR SURE 06+ CIVIC CENTER CAPS Fit into 15 inch rpf1's!
I gave my buddy my center caps and he popped them right into his rpf1's that are 15 inch!
Old 07-27-2016, 05:22 PM
fred9000's Avatar
is the center cap was pop in the wheel with the bore centric ring spacer ?
Old 07-29-2016, 08:39 PM
wtf? not sure wat ure asking but centercaps are just snap fit.
Old 07-30-2016, 06:29 PM
fred9000's Avatar
sorry i you do not understand , the english is not native langage ....
what i mean is rpf1 is aftermarket rim ok? so in the case of these model the center of the rim is bigger than the honda fit bore center so it take un ring or spacer if you prefer ,
at my dealer they install the rpf1 and spacer to fit perfectly the honda fit bore center hub
so what i mean is these civic cap can spnap with the space already there
or if some body who understand the question can answer....
thanks
Old 08-10-2016, 09:17 PM
ykustom's Avatar
Pose la question en francais,je vais peut etre pouvoir te répondre!
Old 08-10-2016, 09:28 PM
fred9000's Avatar
ok , j'ai acheter une fit avec des enkei rpf1 15x7 donc pas de center cap de enkei pour cette grandeur mais j'ai entendu dire qui a du monde qui metais des center cap de civic ou autre modele , je suis ouvert au suggestion , je suis patenteux
Old 08-10-2016, 09:30 PM
ykustom's Avatar
Quel est le diametre du center bore sur tes rpf1?
Old 08-10-2016, 09:40 PM
fred9000's Avatar
ma te dire ça demain la faut je me couche ma prendre la mesure exact demain quand il va faire clair a+
Old 08-10-2016, 09:41 PM
ykustom's Avatar
Parfait tient moi au courrant
Old 08-11-2016, 03:15 PM
fred9000's Avatar
bon moi je mesure 63.5 mm alors que le site de enkei marque 73mm sur des 15x7 c'est ou ben une erreur ou c'est des faux (je sais pas si il se fait des faux de cette marque)
je me suis trouvé des petit cap sur ebay outer face 69mm et inner locking area 64mm en les gossant un tit affaire au dremel devrais fiter
kurisux92
10-03-2011 12:22 PM
FitAK
04-14-2011 01:32 PM
enjoito
04-11-2009 04:34 PM
F.IT
10-03-2008 09:00 AM
MNfit
05-13-2008 10:37 AM
Quick Reply: 15x7-RPF-1 center cap
