Repeat coil misfire
Old Apr 18, 2021 | 10:32 PM
harpersgrove's Avatar
Repeat coil misfire
hi i have a 2014 ram 1500 with 131,000 miles. i keep getting a misfire code on cylinder 1. i had mechanic replace coils and spark plugs. couple weeks later cylinder 1 failed again. i was told to put factory coil in, so i did. couple weeks later cylinder 1 has misfire. mechanic said wire plugging into coil was bad. had them replace that, couple weeks later, misfire on cylinder 1 again. dodge dealer couldn't find a problem. swapped coils from cylinder 2 to 1 and 1 to 2 while it was misfiring. stopped the problem. couple weeks later, misfire on cylinder 1. coil obvs isn't bad. spark plugs were changed, idk what else it can be.
Hydrogirl
Aug 18, 2023 08:03 PM
Nikademo
Nov 9, 2020 02:02 AM
frethack
Aug 13, 2017 04:28 PM
Kegel81
Jan 22, 2017 10:12 AM
macbuddy
May 17, 2014 03:40 PM
