When is the next meet?
Old Dec 11, 2008 | 10:52 PM
sy11580's Avatar
when is the next meet?? Sorry guy I don't have a Fit now, so I didn't come out??
why I missed the meet?? damn
Old Dec 11, 2008 | 11:06 PM
viperjh16's Avatar
every Wednesday on 110 building 1112
Old Dec 12, 2008 | 02:27 AM
Zangoose GD3 Blue's Avatar
who cares stan come with the subary lol
Old Dec 12, 2008 | 08:23 AM
NIGHTHAWKSI's Avatar
Originally Posted by Zangoose GD3 Blue
ill be in huntinton this friday ill drop it off for you... its just sitting in my garage... and as for the boost gauge i still got to look for it, for some reason i might of sold it i cant remember
call or text me later. i shoudl be around to meet up with you.
thanks!
Originally Posted by viperjh16
fog lights flickers or head lights or doesn't work ground the black wire off the ballast to the chassis the red wire to fog light stock wire. Did it to my fit the morning and test drive the fit in wet conditions and it works no problems with my hid fogs or head light hids
HIDs shoudl always be ran with a relay harness. at turn on they draw more than the 35w current they advertise...enough to possibly melt the wiring harness in your car.
if you dont feel like doing a relay harness, make sure all your connections are soldered together and any plugs are tight and then wrapped in tape. also, mount the ballast in a place that is mostly dry and wont have water dripping on it from above.
if you continue to have problems, you might want to get OEM ballasts from a car that comes with HIDs from the factory. ive never had good luck with and aftermarket or ebay hid kits. they always seem to flicker or just not turn on...and by the time you replace the ballasts or bulbs that you think might be the problem, you mind as well just of spent the money in the first place to get quality ballasts that will outlast the car.
Old Dec 12, 2008 | 09:45 AM
MisterBiz's Avatar
I'll try to stop by next Wednesday although I might be crammed up with finals.
Old Dec 12, 2008 | 10:05 AM
thanks!
if you done feel like doign a relay harness, make sure all your connections are soldered together and any plugs are tight and then wrapped in tape. also, mouth the ballast in a place that is mostly dry and wont have water dripping on it from above.
if you continue to have problems, you might want to get OEM ballasts from a car that comes with HIDs fromt eh factory. iv enever had good luck with and aftermarket or ebay hid kits. they always seem to flicker or just not turn on...and by the time you replace the ballasts or bulbs that you think might be teh problem, you mind as well just of spent the money in the first place to get quality ballasts that will outlast the car.
yo def. bro...
Old Dec 17, 2008 | 03:53 PM
viperjh16's Avatar
meet up to night 1112 building any one to night 8:30
cnordt24
New Jersey Community
26
Aug 29, 2014 10:54 AM
isthata_scion
Mid-Atlantic Community
158
Sep 15, 2009 08:28 PM
Prb_ohio
Ohio Community
Apr 21, 2008 08:19 PM
DeadlyAcuraccy
Florida Community
Feb 28, 2008 09:53 PM
dougiepants
Upper Mid-West Community
62
Aug 15, 2006 09:38 AM
