e brake pull + burnt clutch
Old Feb 13, 2008 | 09:27 PM
pastafarian's Avatar
ok I was talking to this kid at my school, and he said that pulling your e brake on snow burns your clutch. He said he had to replace his sti's clutch because of that. I don't see how if the clutch is surpressed or if the car is in neutral that it could hurt. I know its not good for it, but I don't think that it would reduce the clutch's life.
Old Feb 13, 2008 | 11:24 PM
he's talking about his center clutch for his AWD system.
Old Feb 14, 2008 | 02:31 AM
doctordoom's Avatar
Supervillain
are you guys 'drifting' your cars in the snow?
Old Feb 14, 2008 | 10:12 AM
Illusive's Avatar
yeah his AWD would be affected by the e-brake, but the actual clutch wouldn't be. Hell, I do it all the time when we get a nice batch of snow on the ground haha...Oh and never switch over to neutral or depress the clutch when doing some snow drifts unless you are in a wide open space with nothing around you. Once you lose your connection with your engine, you'll have no control over the car.
Old Feb 14, 2008 | 11:19 AM
Firebat666's Avatar
burnt clutch from drfting????? no i was just out drfitng in the snow the other nite... i mean yankin the e-brake certainly isnt the most healthy thing for your car... but the worst its rly gonna do it streach the cable.... lol
Old Feb 14, 2008 | 01:11 PM
EXWRX's Avatar
The center limited slip diff in the Sti could be affected by using the ebrake, if done a lot. Occasional use would be unlikely to damage things, but still has the potential to do so. The Center diff is there to allow for the difference in distance traveled between the front and back wheels around a curve, because the front wheels take a path outside the back wheels. So the diff is designed to allow a few percentage points of difference in wheelspeed. When you go from 1-2 MPH difference to 50-60 mph difference, you are exceeding the design intentions and likely causing excessive wear if not actual damage to the center diff.
Last edited by EXWRX; Feb 14, 2008 at 01:12 PM. Reason: cause I'm sick and braindead
Old Feb 14, 2008 | 07:47 PM
ass dragging
I normally do it in a wide open space (ie empty parking lot)
what gear do you normally leave it in? Bec I thought you'd prob stall doing this. Prob second for the speed i do it at (15 to 25 normally)
Old Feb 14, 2008 | 07:50 PM
Perhaps he burnt the clutch bec he sucks at driving stick lol. No that I'm driving king or anything, but I rode with the kid and he had really jerky shifts. Even from like 3 to 4.
Old Feb 14, 2008 | 10:34 PM
Illusive's Avatar
Originally Posted by pastafarian
ass dragging
Depends how fast I'm going, usually either 1st or 2nd...
civilcivil
Site Feedback and Suggestions
Jun 16, 2010 01:06 PM
Edison Carasio
Off Topic Discussion
Apr 4, 2008 05:30 PM
tonyd3773
Feb 24, 2008 02:30 PM
