#, 89, Si HATCH aka 》》 F and F : ^ )
Old May 30, 2019 | 09:51 PM
  #41
Perrenoud Fit's Avatar
Changed out the tranny fluid, aka motor oil. Replaced with honda mtf, smooth moves after that.
Remounted the steering wheel till it pionts north when driving straight.
Refinished the Si with red base and color shift. Looks red till the sun hits it then it turns purple.
Got 2 100 watt led lights for the garage's outside pad, With these we're open 24/7, lol.
Old May 31, 2019 | 11:17 AM
  #42
Old May 31, 2019 | 10:02 PM
  #43
Replaced the shifter with a brand new short shifter and urethane bushings. Cleaned the s.s. exhaust system which nobody can see but looks shweet. Took her for a test drive to see how the the shifter felt, way better, doesn't feel like I'm stirring a gallon of paint when shifting gears. Then took the grey 89 for some fun, need to drive it more. : ^ )
And hung 1 light. These are are so bright compared to quartz without the heat! And electricity.
It was a good day.
Old Jun 1, 2019 | 08:55 PM
  #44
Changed out the upper control arms, installed a clear timing cover, made a battery hold down, the bungy cord was a little too dangerous.
Old Jun 3, 2019 | 08:08 AM
  #45
Engine bay b4 and after
1st day pulled valve cover off and it went to a blue color
After detailing:
Old Jun 3, 2019 | 09:34 PM
  #46
Color shift on a blue base
Old Jun 4, 2019 | 09:41 AM
  #47
Rear crx flaps installed on ef hatch
Not a perfect match but at 1/5 the price i can deal with it. ; < )
Old Jun 4, 2019 | 02:52 PM
  #48
Old Jun 5, 2019 | 09:40 PM
  #49
Rod knock in the b7.
Installing a d15b vtec with p08 and conversion wiring.
Arriving next week. So let the party begin.
Old Jun 6, 2019 | 09:49 PM
  #50
Fender flares
Old Jun 7, 2019 | 07:43 PM
  #51
The New Motor:
Also new driveshafts, clutch with 8# flywheel, injector rebuild kit, ball joints, inner& outer tie rods, p08 ecu, and obd0 to obd1 harnesses.
The motor has 49.6k miles with all accessories. Using the Si transmission
This is the most indepth i have gone with a build so far with the drivetrain.
Im ready, i better be, right .
Old Jun 9, 2019 | 08:59 PM
  #52
Replaced the hacked harness, and hooked up the rear speakers. Honda lands the rear speaker wires on the rear tail light harness, @ the brake lights.
Old Jun 10, 2019 | 09:06 PM
  #53
Added the last rear fender lip, looks nnice, ;^)
Old Jun 10, 2019 | 09:08 PM
  #54
Dizzy harness arrived and the clutch kit, its so little lol.
Old Jun 10, 2019 | 09:14 PM
  #55
Engine is arriving 6.12.19, my buddy at work and I are trading vehicles, I'll use his truck to deliver the motor from work to home, and he'll drive my Fit! Need to add a little "o poppa's recipe" to the gas for that extra kick. ;^)
Old Jun 11, 2019 | 09:55 PM
  #56
Started prepping to remove drive train. Oil, anti freeze and header.
Old Jun 13, 2019 | 05:53 AM
  #57
The JDM D15B:
This is it! I can see it mow, wrapped header sitting in the ef.
Idk except for the ngr bkr6e 11
Old Jun 15, 2019 | 08:12 PM
  #58
Motor #2
Old Jun 16, 2019 | 06:30 AM
  #59
Old Jun 22, 2019 | 12:37 AM
  #60
Mock up
Got the last pieces from pick n pull today. You can't beat a good find in a junk yard, but 4 or 5 makes the day even shweeter!
Met some really good folks there, helped pull a transmission with 2 guys. Then helped 2 young fellers pull an intake from a z6 motor they're installing it on a CRX that has DP.
Then i found a dc2 console, Kenwood stereo, all my wiring, 2 vtec solenoids. It was a very good evening ; ^ )
