Re: Battery acts weird
Old May 4, 2005 | 11:16 AM
John Ings
Guest
Posts: n/a
On 2 Feb 2005 22:40:41 -0800, mmdir2002@yahoo.co.uk wrote:
>Not the dead battery at all, sometimes I can't start.
>It is not starter or main relay problem. So i charged about
>30 min then it start again. This is third time the battery
>did not working 100%. I don't know if I have to replace
>new battery.
You need to post more details. How old is the battery? Have you
checked the battery's connections and the cables? How cold is it where
you are at the moment?
Guest
Posts: n/a
> >new battery.
where
The battery is about 2yr old. Does the hot and cold weather matter
to the battery condition? If so, tell me about it.
John Ings
Guest
Posts: n/a
It should still be OK then. Car batteries last roughly five years
under normal use.
Oh yes! When the temperature is down, all chemical processes slow
down. If you look at battery specifications, you'll see a spec called
"cold cranking power" which is the ability of the battery put out
decent current at low temperatures.
Your problem however sounds more like cables and connections. Here's
an excerpt from the FAQ
"Then again there's always the possibility you have bad battery
connections or dirty solenoid contacts. Here's how to check. First,
loosten the battery terminals a little and move them a bit, then
retighten. Check where the negative cable is bolted to the body or
engine. If the engine isn't turning and you just hear a clicking sound
from under the hood, turn the headlights on and have someone observe
them while you try to start the car. If they go out, the battery is
being loaded down and can't hack the load. If they stay lit, the
starter solenoid contacts or the starter's comutator is dirty and the
starter isn't drawing its full current. The latter fault is often
intermittent."
More at http://www.tegger.com/hondafaq/faq.html#battery
EXT
Jul 29, 2013 10:53 AM
marokero
Aug 8, 2006 12:53 PM
d_cymbal@hotmail.com
Aug 28, 2005 11:31 AM
Sam Nickaby
Jul 17, 2005 02:51 AM
piclistguy@yahoo.com
May 4, 2005 11:16 AM
