Odyssey transmission troubles?
Guest
Posts: n/a
Re: Odyssey transmission troubles?
Local dealership ran out of "loaners" to cover the Accords/Odys that were
sitting awaiting rebuilt trannys to come in from Honda.
The techs get 6-7 hours time to do swap in the rebuilt trannys, usually can
get it done in 3.5-4 hours. That includes replacing the ECU in the Accords
which detunes the engines power output so the rebuilt trannys will last
longer.
"chip" <hs4797@brevard.net> wrote in message
news:s5fn21t62fbprr7f6q5c60eg0ravrcancu@4ax.com...
> On Sun, 06 Mar 2005 21:15:43 GMT, "Mista Bone" <mistab0ne@nospam.net>
> wrote:
> >How to kill a Honda Accord/Ody tranny in 30 secoonds or less........
> >Step on brakes HARD, step on GAS hard. In 30 seconds or less you'll kill
the
> >tranny. Honda covers under SILENT extended warranty because the trannys
are
> >JUNK!!!!!!
> >Last time I heard there was a 3-4 week waiting list of people waiting to
get
> >rebuilt trannys from Honda, they are backlogged that bad!
> >"Silent Recalls" gotta love the idea :)
> granted honda trannys are getting a bad reputation, but tranny
> replacement only accounts for about 3% of warranty claims.
> as for 3-4 week waiting list... did you pull that number out of yor
> ass????? Whenever i order a tranny, it gets there within 3 days.
> always has.
> silent warranty? there's an open campaign on them 7years or
> 100,000 miles, published in the papers, not so silent.
> Chip
longer.
the
are
> >JUNK!!!!!!
get
> always has.
> Chip
Guest
Posts: n/a
"Glenn Holliday" <holliday@acm.org> wrote in message
news:423D7BF8.29424801@acm.org...
> "E. Meyer" wrote:
>> On 3/13/05 8:02 PM, in article 4234F0A8.27E73730@acm.org, "Glenn
>> Holliday"
>> >> Chip
>> > I assume you're thinking of a different model/year? I looked
>> > again at my warranty book on the '02 Odyssey, and it says
>> > 36,000 miles. Did I miss out on something? (I just clicked over
>> > 100,000 miles since my original post.)
>> Its not in the warranty book. You should have gotten a letter from
>> Honda.
> Nope, we got 2 recall notices on this vehicle, but nothing about
> extending the warranty.
> Glenn Holliday holliday@acm.org
If you are in the US, you can register on the owner's link on the Honda
webpage and it will list all the recalls and warranty extensions that
specifically apply to your vehicle. Since you've already gone over 100,000
miles though, its probably moot unless you can find a kind hearted dealer.
Guest
Posts: n/a
Is your automatic a 4-speed or 5-speed? IIRC, the extended warranty
applies to the 4-speed, while recalls were issued for the 5-speed.
Guest
Posts: n/a
> One day last week my 2002 Odyssey suddenly refused to shift up
> from 2nd into 3rd.
Yesterday this happened again. I found that if I backed off and
accelerated extremely gently, the trans then shifted normally.
This car has not been subjected to fierce acceleration.
It's now at 100,700 miles, none of them abusive, and the
transmission has not exhibited a problem until the past 3 weeks.
Still no check engine light, so Honda says they can't do anything
about it.
I'm grateful for the replies to this thread. It sounds like
others have other troubles with this transmission, but this particular
symptom is not well-known.
I'm going to have to decide if it's safe to take my family far
from home in this car for Easter. I'll let you know if I learn
more facts about this problem.
> from 2nd into 3rd.
about it.
Guest
Posts: n/a
"E. Meyer" wrote:
> On 3/13/05 8:02 PM, in article 4234F0A8.27E73730@acm.org, "Glenn Holliday"
> >> Chip
> Its not in the warranty book. You should have gotten a letter from Honda.
> >> Chip
Guest
Posts: n/a
> Thanks for the advice.
>> Chip
>> Chip
Guest
Posts: n/a
> Chip
> Chip
Guest
Posts: n/a
In article <qs4q21pt3ic782c085adveuj177nu9glc0@4ax.com>,
chip <hs4797@brevard.net> wrote:
> hoda pays for a rental car on the warranty if the car stays.
> the odessy has an updated ECU, but haven't seen on e for an
> accord.
> flate rate time is 5-6 hours, and after doing many of them
> yes i can get it done in just under 2.
> honda has 3 companies i believe doing rebuild now.
> the bought up cores from bone yards everywhere. if they don't have
> reman, i've gotten several brand new ones.
> all internal components are replaced and each one is dyno
> tested now.
Yeah, but are they just putting the same bad designs back into the cars,
or have they fixed the design?
> accord.
> tested now.
Guest
Posts: n/a
On Mon, 07 Mar 2005 06:47:53 GMT, "Mista Bone" <mistab0ne@nospam.net>
>longer.
accord.
tested now.
Chip
>longer.
accord.
tested now.
Chip
Guest
Posts: n/a
from 2nd into 3rd. I was in slow moving city traffic at the
time. I pulled off, turned the car off, restarted, and all was
well after.
The car was checked for the trans heating recall two months
ago. The dealer at that time said there was no problem with
my trans, and made no changes then.
A Honda dealer service desk and two independent trans shops all
told me they've never heard of this. None of them can do any
diagnostic unless it turns on the check engine light or the
problem becomes repeatable. I also can't find any mention of
this symptom on the Internet.
Is there any history or knowledge about this problem?
Is the correct remedy don't worry, be happy till it
happens again?
Thanks for any info.
well after.
happens again?
Guest
Posts: n/a
> Step on brakes HARD, step on GAS hard. In 30 seconds or less you'll kill the
> tranny.
just curious what FWD tranny *would* be able to deal with abuse like that?
> tranny.
Guest
Posts: n/a
In article <s5fn21t62fbprr7f6q5c60eg0ravrcancu@4ax.com>,
I think he's referring to the fact that Honda has always had quiet
campaigns where they take care of people who appear to fall outside of
the published recalls.
Go back and look to see if there was any official recall for the 79
Civic for either its front beam or its gas tank. You won't find
it--because they never did recall those. However, if someone came in
with a problem, Honda quietly took care of it.
Now, myself, I don't mind Honda's quiet methods. I'm the type who will
ask for Honda to take care of things, and if there's an "unofficial,
quiet" campaign, Honda will.
However, the people who get all bent out of shape about something like
that are the people who expect that they should never have to ask, that
they should be spoon-fed everything they want if it's available in any
capacity whatsoever. These people expect the service writer or service
manager to offer to handle everything without ever being asked.
In other words, these people want the moon.
I say, go ask for what you want. The world is not here to serve any of
us. At least ASK for Honda to take care of an obvious problem.
So with respect to transmissions, are there situations where Honda is
replacing transmissions for issues that appear to be outside the recall?
Undoubtedly. Are they advertising that fact? Undoubtedly not.
Guest
Posts: n/a
>tranny. Honda covers under SILENT extended warranty because the trannys are
>JUNK!!!!!!
>Last time I heard there was a 3-4 week waiting list of people waiting to get
always has.
Chip
>JUNK!!!!!!
always has.
Chip
Guest
Posts: n/a
JUNK!!!!!!
"Elmo P. Shagnasty" <elmop@nastydesigns.com> wrote in message
news:elmop-0CFE4A.08174506032005@text.usenetserver.com...
> In article <qo5l21lbekb4kmagpfsb1ea32co777mube@4ax.com>,
> > >This is the age of the net. They can't hide behind the "we've never
> > >heard of it before" defense.
> > if you can't duplicate the symptom, the dealer won't waste their
> > time. they don't give a crap about odyclub.com. you either have a
> > problem or you don't
> People on odyclub report using the reports on odyclub.com to force
> Honda's hand. Honda does its best to claim that they've never heard of
> something, but having proof that someone else's transmission was
> replaced by Honda for the exact same issue is pretty damn strong.
> They can't hide behind the "we've never heard of it before" defense when
> there's hard proof that Honda has indeed heard of it before, to the
> point where Honda replaced the transmission for free.
JUNK!!!!!!
Guest
Posts: n/a
Guest
Posts: n/a
On Sat, 05 Mar 2005 11:05:30 -0500, "Elmo P. Shagnasty"
<elmop@nastydesigns.com> wrote:
>In article <4229D249.8F96B3C4@acm.org>,
>> well after.
>> happens again?
>http://www.odyclub.com
>I guarantee there's history and knowledge of this problem. People at
>odyclub.com have even used what's posted on odyclub.com to make Honda
>pony up for a new transmission.
Chip
>> well after.
>> happens again?
Chip
Guest
Posts: n/a
> well after.
> happens again?
> well after.
> happens again?
All_Star_Tio
May 4, 2005 11:16 AM
