Q for Honda techs
Old May 4, 2005 | 11:16 AM
Tim Klechak
Guest
Posts: n/a
Q for Honda techs
Sorry to repost this, but I didn't get a response from my first post
.....O.K., seems like I only pop in here when I have a problem and need
advice,
but ........
O.k., I did a valve job on a 1987 Prelude 1.8 carbureted engine, and am just
about done, except I need to tighten up the intake manifold. My question is
this ..... how the heck do you get access to the lower middle stud/nut???
Can it be accessed by going between the carbs around any vacuum/fuel lines
etc.??? I have the air cleaner assembly off already, including the backing
plate. Please respond to this group AND by email if you've done one of these
intakes before. The Haynes manual I have simply says "remove nuts & bolts"
...... DUUUHHH
Any tips would be appreciated. TIA .... Timm .........
tklechak@cocsd.k12.az.us
jim beam
Guest
Posts: n/a
Re: Q for Honda techs
> advice,
> but ........
> ..... DUUUHHH
in the immortal words of the haynes manual, "assembly is reverse of
removal".
Tim Klechak
Guest
Posts: n/a
Jeeez, I couldn't of figured that out myself! Thanks Haynes!! ;^)
"jim beam" <nospam@example.net> wrote in message
news:1112190654.2ea8daae28513d693f5895dbbdf4089d@t eranews...
>> advice,
>> but ........
>> just
>> is
>> lines
>> backing
>> these
>> bolts"
>> ..... DUUUHHH
> removal".
Steve
Guest
Posts: n/a
I had a offset boxend, Hadn't used it in ohhh, 15 years, but I used it on
that one.
Stephen W. Hansen
ASE Certified Master Automobile Technician
ASE Undercar Specialist
"Tim Klechak" <tklechak@cocsd.k12.az.us> wrote in message
news:3zy2e.2$5z2.206@news.uswest.net...
>>> advice,
>>> but ........
>>> just
>>> is
>>> stud/nut???
>>> lines
>>> backing
>>> these
>>> bolts"
>>> ..... DUUUHHH
>> removal".
Eric
Guest
Posts: n/a
> advice, but ........
> just about done, except I need to tighten up the intake manifold. My
> question is this ..... how the heck do you get access to the lower middle
> stud/nut???
> these intakes before. The Haynes manual I have simply says "remove nuts
> & bolts" ..... DUUUHHH
This question has come up a few times in the past. Instead of repeating the
post, I've included a couple of links to my prior answers to this question.
I hope that these prior posts will be helpful. Tegger, maybe this
information could be put in your FAQ if it's not there already.
http://tinyurl.com/4a8u3
http://tinyurl.com/4glht
http://tinyurl.com/472jn
Eric
De36
Aug 9, 2023 10:45 PM
Koi
Nov 29, 2014 06:04 PM
MikeLikes
Jul 17, 2005 11:30 PM
Darellbrownnose
May 18, 2005 11:20 PM
Eric
May 4, 2005 04:44 PM
