simple brake question
Old May 4, 2005 | 11:16 AM
merlotbrougham@hotmail.com
Guest
Posts: n/a
92 Civic EX
My ABS light is on and by the Chilton's manual it could be any of a
number of problems. The brakes are well worn and it's time to replace
the rotors (at least). My question is: does the ABS have any sensons
that would prohibit me from doing a normal brake change (rotors, pads)?
I'd rather do the cheap stuff myself before I have to have it hooked to
a dealer computer.
E. Meyer
Guest
Posts: n/a
Re: simple brake question
On 3/30/05 8:02 AM, in article
1112191341.107246.6230@l41g2000cwc.googlegroups.co m,
"merlotbrougham@hotmail.com" <merlotbrougham@hotmail.com> wrote:
> 92 Civic EX
> a dealer computer.
There is nothing special about changing brakes with ABS. Just be careful
not to mess up the wheel sensors or the wires to them. Why do you want to
change the rotors? If they're not warped or deeply gouged from running the
pads to the bare metal, you should be able to simply replace the pads.
Guest
Posts: n/a
Well, it's not that I want to replace them, but they're pretty thin
(one rear one is rusted) and sometimes instead of waiting for the shop
to turn them, it's cheap enough just to replace. I think Pepboys or
Autozone has them for $22. and the cost to turn them is ~$12. Thanks
for the input- I'll get on them this weekend.
> > 92 Civic EX
replace
sensons
pads)?
hooked to
> > a dealer computer.
careful
want to
running the
pads.
Ammonman
Guest
Posts: n/a
If one rear rotor is rusted, you either have a bad caliper or the slide pins
are seized inside the caliper frame. Check the rusty rotor. If it is just
rusted on one side, then the caliper is stuck and can not float to center
itself on the rotor and only one pad is making contact with the rotor.
Remove the pins and either clean and lube or replace. Plan on replacing the
rubber boots that go on the pins.
Ammonman
<merlotbrougham@hotmail.com> wrote in message
news:1112203386.659007.215660@o13g2000cwo.googlegr oups.com...
> > > 92 Civic EX
> replace
> sensons
> pads)?
> hooked to
> > > a dealer computer.
> careful
> want to
> running the
> pads.
phenoyz
Jun 3, 2014 11:52 PM
Goobers
Sep 1, 2011 05:16 PM
mjletts
Aug 23, 2009 09:07 AM
Jonniedee
29
Oct 13, 2007 06:19 PM
leonine
17
Sep 22, 2007 03:38 AM
