Re: 88 civic SI burning oil at acceleration...
Old Jul 7, 2005 | 03:22 AM
SoCalMike
Guest
Posts: n/a
Eric wrote:
> but not always. It seems it may be somewhat weather dependant. When
> it's hot it's usually bad. Also, often it doesn't smoke at all. I've
> cleaned the PCV tube and valve but still get smoke sometimes, it's
> bluish.
> Are my rings worn?
youll need a compression check. do the test, then squirt some oil in the
cylinder and redo the test. if the results are better, then its the rings.
> I understand that if the rings are worn there's little to nothing one
> can do about it.
> Does a heavier oil help?
slightly. what are you using now? i wouldnt go over a 20w50 at the
absolute most. maybe synthetic might last longer?
how many miles on it?
RayGun
Aug 14, 2005 12:32 AM
RayGun
Aug 12, 2005 02:30 PM
RayGun
Aug 10, 2005 11:36 PM
TeGGeR®
Jul 7, 2005 01:26 AM
mike113
May 4, 2005 04:44 PM
