why short the service check connector when setting timing?
Old Sep 4, 2005 | 05:30 PM
chibitul
Guest
Posts: n/a
I followed the instructions step-by-step to check the ignition timing
in my 1997 Civic LX. It was maybe 1/2 degree out of spec, I set it
where it should be.
Now, I want to know why you should jumper that service check connector
when you do this? what happens if you don't jumper this connector?
BTW: I could not locate the other connector (the 3-pin connector for
data). I found where it should go in that rubber thing, but I cannot
find the connector and the wires. Maybe 97 doesn't have one?
next thing I want to check is the PCV, but I cannot identify the valve,
even though I have some "diagrams" I am probably looking at it, but I
cannot "see" it :)
Elle
Guest
Posts: n/a
Re: why short the service check connector when setting timing?
If you don't jumper as directed, then as you try to adjust the timing by
rotating the distributor housing, the engine control system will
simultaneously attempt to undo what you do.
> cannot "see" it :)
At whose diagrams are you looking?
Try this drawing for a 97 Civic DX (which looks a lot like the 96 and 98
Civic LX drawing):
http://www.hondaautomotiveparts.com/...p?inputstate=5
&catcgry1=Civic&catcgry2=1997&catcgry3=4DR+DX&catc gry4=KA4AT&catcgry5=BREATH
ER+CHAMBER+%281%29
Note the "Front" direction arrows on the drawings. The "breather chamber,"
to which the PCV valve connects, is something like 4 to 6 inches by 4 to 6
inches, about an inch thick. Painted black.
I couldn't get an LX drawing via this site, but www.slhonda has a drawing
for the 97 civic lx that looks like the above.
It also helps having a new PCV valve in your hand, matching it to what you
see under the hood.
On the other hand, I think someone posted here in the last couple of years
that getting at the PCV valve on his late 1990s Honda was a pain. I think
the poster said he had to get at it from under the car. From the drawing,
this might be one of those Hondas. Take a flashlight with you, or make sure
the sun is shining on the top of the engine when you check.
By contrast, people talking about early 1990s Hondas will report it's easy
to get at (from the top, with little in the way to remove it).
Old Sep 4, 2005 | 06:37 PM
jim beam
Guest
Posts: n/a
> where it should be.
> cannot "see" it :)
if you leave it unconnected when you run the timing light, you'll see
the timing mark jump about as the ecu varies timing. with the service
connector shorted, it holds the timing steady so you can set it right.
just keep checking for the pcv. it /will/ be there.
Old Sep 5, 2005 | 10:36 AM
TeGGeR®
Guest
Posts: n/a
"chibitul" <chibitul@sbcglobal.net> wrote in
news:1125865969.551644.22620@f14g2000cwb.googlegro ups.com:
> where it should be.
When you set the distributor, you are setting the "base" timing, which is
the datum from which all other adjustments are made. This floor must be
correctly set, otherwise everything else may be off.
Jumping that connector prevents the ECM from being able to adjust the
timing while you're setting it, so you are for sure setting the "base"
timing without interference from the computer.
It is not a given that the ECM will adjust the timing, but if it does, your
base setting will be messed up.
You mean the OBD connector?
http://www.tegger.com/hondafaq/faq.html#retrieve
> cannot "see" it :)
http://www.tegger.com/hondafaq/pcv-replace/index.html
TeGGeR®
Bolduer
Jun 6, 2019 07:05 PM
contagiouss_blue
May 23, 2015 09:07 PM
Shora
Mar 11, 2009 02:21 AM
MikeLikes
Jun 4, 2005 11:09 PM
GodsShoeshine@gmail.com
May 4, 2005 04:44 PM
