2003 Accord, Compressor won't turn on
Old Sep 11, 2005 | 10:31 AM
got80s
Guest
Posts: n/a
I recently purchased a used 2003 Accord. While driving down the highway
last night the A/C stopped blowing cold air. I figured maybe the "freon"
was low. I ran by my brother-in-laws and he checked the level of the freon
and said it's fine. He said the compressor isn't kicking on. We can only
assume that it is a blown fuse that controls it. However I can't figure
out what fuse controls it, even after looking at the manual. Anyone just
happen to know?
Old Sep 11, 2005 | 11:37 AM
Elmo P. Shagnasty
Guest
Posts: n/a
Re: 2003 Accord, Compressor won't turn on
In article
<d2e7fde54c6d580874e4f90065b97e95@localhost.talkab outautos.com>,
> happen to know?
Are you under 36K miles? If so, head to the dealer.
got80s
Guest
Posts: n/a
no i'm the second person to purchase it, i'm at 54k
Old Sep 11, 2005 | 04:30 PM
SoCalMike
Guest
Posts: n/a
> happen to know?
not offhand. there are probably fuses under the hood as well as under
the dash. the manual should say *something*. if not, id disconnect the
battery and pull fuses one at a time.
Woody
Guest
Posts: n/a
The fuse compartments should be labeled. All you have to do is find them. If
you plan on servicing the car yourself now is the best time to invest in the
Helm manual for it. It will have the wiring and fuse information in it. You
might also try your local library.
"got80s" <brad@nospam.somethingeasy.net> wrote in message
news:6fa904f8d3110fba3dbe22b7845ffb45@localhost.ta lkaboutautos.com...
Old Sep 11, 2005 | 10:32 PM
High
Guest
Posts: n/a
> happen to know?
My daughter's 2000 Accord V6 had the same problem. The cause was a
defective relay in the fuse box under the hood. If I remember correctly,
there were 3 identical relays, one for the compressor, one for the a/c
condenser fan and one for the cooling fan. I switched the compressor
relay with one of the fan relays to trouble-shoot the problem, the
compressor started but the fan wouldn't, then drove my old bike ('77 750
Hondamatic) to the junkyard and pulled all three from a wrecked Accord
(no charge!)
This may or may not be your problem but if you decide to trouble-shoot
the problem this way make sure you identify the relays, read all of the
numbers on them to make sure they are identical. They may have changed
between 2000 and 2003. Also after you replace the relay or if you decide
to drive the car before you replace the defective relay make damn sure
both fans are working. (you may have left the defective one in one of
the fan slots by mistake, kinda like a shell game)
Old Sep 12, 2005 | 03:31 PM
got80s
Guest
Posts: n/a
Thanks for all the help. I am on my way to the shop this afternoon. The
dealer I bought it from is very helpful, considering my sister issues all
the loans for his cars.... I can assume it is the relay since that is the
second time I have heard that. I'll let you know what the shop says.
Old Sep 14, 2005 | 08:30 AM
got80s
Guest
Posts: n/a
looks like it was the coil in the compressor clutch. thankfully repaired by
the dealer. part was like 40 bucks..
Panthese
33
Aug 18, 2020 12:08 PM
Sjensen9
Aug 8, 2015 11:13 AM
integradriv3r
Feb 22, 2007 12:19 PM
cmilner2
Aug 25, 2005 12:33 AM
TeGGeR®
May 15, 2005 07:30 PM
