Antifreeze issue
Old Oct 11, 2005 | 11:31 AM
Elle
Guest
Posts: n/a
Re: Antifreeze issue
"Mike S." <retsuhcs@xinap.moc> wrote
> SoCalMike <Mikein562athotmail@hotmail.com> wrote:
> >Mike S. wrote:
> >> At first I feared they had used an old Prestone-like silicate formula
> >> but in view of the above perhaps it isn't. On Monday I'm going to call
> >> them and see if I can ascertain exactly what they did put in my
radiator.
> >i definately would. chances are, theyre using the lowest-priced bulk
> >stuff they can get. id guess thatd be regular prestone, with all them
> >phosphates that are bad for hondas.
> I called Firestone. They tell me the green antifreeze they install is
> DexCool. As I understand this is organic-acid based.
I'm not finding any support on the net for Dexcool being green. Make them
tell you the exact brandname.
Firestone: Years ago I used them, but in hindsight, they did not do a good
job. Maybe I'd trust them for an oil change or new tires, at most.
Old Oct 11, 2005 | 12:31 PM
Mike S.
Guest
Posts: n/a
In article <QCQ2f.1466$y14.211@newsread3.news.pas.earthlink.n et>,
>radiator.
I can't find support for that either, except for comments that you can't
make conclusions based on color.
Firestone says the stuff if marked "Advanced A Plus".
In retrospect it was a mistake. I'm just trying to firugre out what, if
anything, to do now ... and how soon.
Elle
Guest
Posts: n/a
formula
call
> >radiator.
I myself wouldn't say that so quickly. The color coding is there for a
reason.
Huh. I guess you googled already. I myself found nothing on the net on this
stuff.
good
Want to try a drain and fill yourself?
It's really no harder than an oil change...
I figure if you do something within a month, no serious damage will result.
Old Oct 11, 2005 | 03:30 PM
T L via CarKB.com
Guest
Posts: n/a
Last time I went to my dealer in Steinbach Manitoba they asked me whether I
needed type I or type II coolant. I had no idea, so I made them look it up.
My 98 civic takes type I, which means it takes any generic coolant. So they
sold me a jug of NAPA green stuff.
t
TeGGeR® wrote:
>> You can get Honda premixed or not. They sell both.
>Not around here (Peoples' Republic of Kanada). Premix or nothing.
>Your Mileage, as the old saw goes, May Vary. Ask your dealer.
Message posted via CarKB.com
http://www.carkb.com/Uwe/Forums.aspx...-cars/200510/1
TeGGeR®
Guest
Posts: n/a
"T L via CarKB.com" <u10197@uwe> wrote in news:55b0b82efb372@uwe:
> whether I needed type I or type II coolant. I had no idea, so I made
> them look it up. My 98 civic takes type I, which means it takes any
> generic coolant. So they sold me a jug of NAPA green stuff.
But was it LONG LIFE "generic green stuff", or was it the old-style
silicated stuff?
TeGGeR®
www.tegger.com/hondafaq/
Old Oct 14, 2005 | 10:30 AM
T L via CarKB.com
Guest
Posts: n/a
Not sure Tegger, suppose its silly but I trusted the dealer when they said
"Here use this stuff". I don't think its long life, whatever that means. I
just chucked the bottle out the other day too. Crap.
A while ago i talked to a different dealer, they told me that the antifreeze
was meant to last the life of the vehicle. And the brake fluid and clutch
fluid too.
That time I didn't just listen blindly, I found a different dealer.... :)
t
>silicated stuff?
Old Oct 14, 2005 | 09:30 PM
jim beam
Guest
Posts: n/a
> fluid too.
no kidding! smart move...
> t
>>silicated stuff?
Old Oct 14, 2005 | 11:30 PM
TeGGeR®
Guest
Posts: n/a
"T L via CarKB.com" <u10197@uwe> wrote in news:55d42c39019a0@uwe:
> said "Here use this stuff". I don't think its long life, whatever
> that means. I just chucked the bottle out the other day too. Crap.
> antifreeze was meant to last the life of the vehicle.
They told you that and they have a Honda franchise???
> And the brake
> fluid and clutch fluid too.
Damn straight. They're f***ed in the head.
TeGGeR®
Old Dec 23, 2008 | 07:30 PM
prufrock's Avatar
I know that these posts are old ones, but I need to know about this antifreeze issue for my '09 Fit. When cold, the level is very low. I called the dealer and he said that this was normal. He also said to check the level when then engine was hot. He warned me to avoid mixing generic coolants and that I should just refill with the Honda brand. How much of this is true?
hondafitzzz
Apr 21, 2009 07:02 PM
mmdir2005@yahoo.com
Oct 17, 2005 03:37 PM
Abeness
Jul 25, 2005 12:32 PM
TeGGeR®
Jun 27, 2005 08:22 AM
mmdir2002@yahoo.co.uk
May 4, 2005 04:44 PM
