1968 ~ 2011 Opel (GT - Manta - Calibra)
Old Jan 18, 2009 | 07:01 PM
Sid 6.7's Avatar
Why so serious?
Opel GT (1968-1973)
Its styling has been likened to the 1968 Chevrolet Corvette which went on sale in September 1968.
The Opel GT was equipped with a base 1.1 L OHV straight-4 engine, which produced 67 hp (SAE) at 6000 rpm. However, most buyers chose an optional 1.9 L Cam-In-Head (CIH) engine, which produced 102 hp (SAE) at 5200 to 5400 rpm. Some of the early 1968 models also came with a slightly higher compression "H" code cylinder head. In 1971, due to emissions regulations, Opel reduced the compression ratio of the U.S.1.9 L engine and output fell to 83 hp (SAE). There was also a GT/J model, which was a less expensive version of the 1900GT sold only in Europe. Standard transmission was a manual 4-speed. A three-speed automatic was available with the 1.9 L engine. The model run of the Opel GT was from 1968 to 1973.
Opel Manta A (1970-1975)
Number one: the chassis and engine of the first came from Manta Ascona, the name lent itself Opel with a stingray
From mild to wild: During the smallest engine in Manta A 1100 petite 60 hp at the rear axle sent, provided the two-liter engines of competition cars around 200 hp.
Great success: From 1970 to 1975 Opel built nearly half a million Manta A
At the end of sports: four round tail lamps in a sharp edge demolition were simply mandatory for sports cars. The light edge in the trunk lid is still not out of fashion
Solid machine: The 90 hp 1.9-liter, with the 970kg(2,134lbs) of light Manta A little effort
Opel Manta B 400 (1981-84)
The Manta 400 served as a base for the rally sport. Of the 144 horsepower 2.4-liter four-cylinder coupe that accelerated up to 210km/h(131mph)
245 units built
Opel Manta B (1975-1988)
So much tuning factory was rare: skirts, spoilers, rally mirror and anthracite-colored wheels were standard in Premium GSi
Long and lean: The Manta B is 4.44 meters long, 1.67 meters, but narrow
Empty weight about 1,000kg(2,200lbs). With the two-liter injection engine and 110 horsepower, the four-seater, very good progress. Maximum 187km/h(117mph)
Engines where available ranging from the small 1,2 litre OHV engine, the 1,6 litre CIH and the 1,9 litre CIH. Also in 1976 the GT/E engine from the Manta A series was adapted into the Manta B programme spawning the GT/E Manta B series. In 1979 the GT/E had the engine replaced with the new 2,0 litre CIH and with a new designed Bosch L injection system. Power output was now 110 bhp (82 kW). The 1.9 litre engine gave way to the 2,0 litre S engine which was aspirated by a Varajet II carburettor. This engine was the most used engine by Opel at the time, and was to be found in several Opel Rekord cars.
Opel Calibra (1990-1997)
The Opel Calibra also known as the Chevrolet Calibra in South America, the Holden Calibra in Australia and New Zealand, and the Vauxhall Calibra in the United Kingdom is a sports car produced by German automaker Opel between 1989 and 1997.
Coupé success: The first was Calibra 1990 to 1997 nearly 240,000 units built.
2.0L 16V Calibra Turbo 4x4 - 204 hp, all-wheel drive, 250km/h(156mph) maximum speed.
2011 Opel Calibra
The strongest unit, the two-liter turbo, comes to 250hp. Enough for a sports coupe. Additionally, there will be a 1.4-liter - and 1.6-liter turbo engine with outputs from 130 to 200 hp and 110 to 190 hp turbo-diesel
Old Jan 18, 2009 | 07:05 PM
kelsodeez's Avatar
UNBANABLE
i remember reading somewhere that the mach 1 from the cartoon speed racer was based off of a first generation opel gt. i can totally see the resemblance.
Old Jan 18, 2009 | 07:11 PM
kylerwho's Avatar
spoon fed
the opel gt reminds me of the toyota 2000gt that was never seen in the states. that was the original speed racer mach 1 design since speed racer was a jdm cartoon.
Old Jan 18, 2009 | 11:37 PM
J_L's Avatar
J_L
In high school an opel gt was the $hit unless you had a muscle car (Z28, Firebird, Charger or GTO) What a great body design.
Fitcious
Jul 21, 2010 01:21 PM
Sid 6.7
Jan 12, 2010 10:26 PM
Sid 6.7
Jan 9, 2010 09:39 PM
Sid 6.7
Jan 8, 2010 02:20 PM
Sid 6.7
Dec 3, 2009 06:52 AM
