Ferrari 348 TS 30k Mile Service
Old Mar 10, 2009 | 11:41 AM
Sid 6.7's Avatar
Why so serious?
The debate will always rage on whether the 348 or the 355 was the better Ferrari, but there's no denying that the small-displacement, high revving V8s located between the flanks of both cars were simply epic. From a design standpoint, the distinct 80s flavor of the gills on the side of the 348 make it an instant personal favorite, though some of the technical details are what seal the deal.
When released in 1989, the 348 was equipped with the Tipo F119D, a 3.4-liter quad-cam, 4-valve per cylinder, dry-sump lubed V8, which produced 300 horsepower at launch and 320 horsepower in later iterations. The 90° V8 was a development of the Ferrari 328 and featured a bore and stroke of 85 x 75mm respectively. Peak power was reached at 7200 rpm with a 10.4:1 compression and used a Bosch Motronic M2.5 fuel injection system.
The 348 marked a departure from previous small Ferraris by having an engine situated longitudinally and its gearbox transversely, a layout similar to the Ferrari 288 GTO and F40. Helping this change was the switch from a tubular steel chassis to a pressed steel chassis with a tubular engine sub-frame that also helped Ferrari comply with new global crash test regulations. Another major change was made at the request of Ferrari's racing program; the entire engine was attached to the rear suspension system and required full removal for any major servicing. It also made for easy powertrain replacement in the future 348 Challenge cars.
What we're looking at today is the removal of said engine in order for it to receive its 30k servicing and according to its owner sameerrao, from The Auto Union, it will receive a new water pump and Hill Eng tensioner bearings as well as a full inspection of a cam leak on the right side, the lower drive pulleys and a strange tapping sound coming from the left cylinder bank. Looks pricey!
Sid 6.7
Jul 1, 2009 12:53 PM
Sid 6.7
Jun 21, 2009 02:32 PM
Sid 6.7
Jan 17, 2009 12:31 PM
Sid 6.7
Dec 23, 2008 10:33 PM
Sid 6.7
Aug 3, 2008 12:39 AM
