The Honda Jazz / Fit Suspension Thread
I just found this.......http://cgi.ebay.com/ebaymotors/TANAB...09589394QQrdZ1
Is it a good price?????
impressie Ben :thumbsup:
may i ask..is this setting =>
this height at the front? =>
cause from the first pic it seems tat u still hav a fair bit of drop allowance.
and by the way.. wth tat drop, hows the ride feeling? from my experience..the jazz/fit isnt built to withstand such dumpage, the bushings; control arms and A brackets are all under alot of pressure tat they arnt allow to absord or depress much further. hence causing even firmer ride. are u fidning the same?
Here's another one to add to the list:
Swift Springs
Swift Lowering Springs: Progressive Springs. Spring rates are 3 kg front and 5.6 kg rear. Will lower the front by 1.18 inch and 0.98 inch in the rear. Comes with 3 years unlimited mileage warranty on the springs for defect or sagging if install by qualify technican.
History of Swift Springs:
http://216.105.56.102/index.asp?PageAction=Custom&ID=91
The Spoon Sports Honda Fit that race in this country use the Swift Springs for their coil-overs and if it is good enough for Spoon Sports, certaintly it is good enough for the rest of us.
Please note that the below Spoon Sports Fit is using their Coil-overs kit with Swift Coil-over springs, these lowering springs will not lower this much of course. I will post pictures of it as soon as we have it installed on our Honda Fit.
prices will be set at a later date.
http://yhst-1408381693991.stores.yah...pfitgd3lo.html
Swift Springs
lowering springs
Originally Posted by Jimmy101
I was just informed these will hit the USA next week.
Pricing will be around $280.
Drift factory, icb motorsports and others will have them soon.
I think they offer the smallest drop of any springs out there.
The EIBACH product no. for the FIT
1. SPORTLINE PART: 4.6940 front 2.0in rear 1.8in
2. PRO-KIT PART: 4069.140 front 1.6in rear 1.3in
Might make the little FIT a bit more stiff to say the least. I will probably put the PRO-KIT on.
The ass-end does not stick up like the MUGEN hmmm?
Hi, I'm new to this forum, i hope someone could help me out, i find a set of 2nd hand GAB suspension kit wagon type? any comments or experience about this produce? becoz currently I'm using Kyb shocks and some unknow brand of spring... whats the different between the GAB wagon and some tein super wagon etc? also this GAB wagon suspension, they are coilover right? thanks
Hi All:
I'm trying to find out if Skunk2 lowering springs are what I really want for my currently stock daily driver (just starting to begin mods).
What are my Pros and Cons?
Thanks everyone for you Opinions/suggestions/help/advice
Springs
If you are able to provide or correct any information on springs, please do so in this thread and I'll try to keep this updated. Also, if you feel other information should be added, please suggest.
If you have side-view photos of your car, preferrably on stock wheels and tires, please post them here and I will add them as well. If you have aftermarket wheel or tire sizes, please post those as well. Again, stock wheels and tires are preferred for comparison.
__________________________________________________
Key Information
Advertised Drop: Front/Rear in. (Front/Rear mm)
Advertised Spring Rate: Front/Rear lbs./in. (Front/Rear kgmm)
Linear or Progressive
OEM
Spring Rates?
Eibach Pro-Kit
Advertised Drop: 1.6/1.3 (40.6/33.0)
Eibach Sportline
Advertised Drop: 2.0/1.8 (50.8/45.7)
H&R Sport
Advertised Drop: 1.6/1.4 (40.6/35.6)
Progress
Advertised Drop: 1.5/1.3 (38.1/33.0)
(CarDemon)
Skunk2
Advertised Drop: 1.5/1.0 (38.1/25.4)
Advertised Spring Rates: 175/350
Spoon
Advertised Drop: 1.5/1.0 (25.4/25.4)
Advertised Spring Rates: 195/291
(macks75)
Sprint
Swift
(Jimmy101)
T1R S-Coil V2
Advertised Spring Rates: 179/342
(aj-racing.com)
Tanabe DF210
Advertised Drop: 1.8/1.3 (45.7/33.0)
Advertised Spring Rates: 174/274 (3.1/4.9)
(jits14)
Tanabe GF210
Advertised Drop: 1.5/0.9 (38.1/22.9)
Advertised Spring Rates: 190/279 (3.4/5.0)
(bulletproofautomotive.com)
(4dr4life!)
Tein H.Tech
Tein S.Tech
Advertised Drop: 1.8/1.2 (46/31)
Advertised Spring Rates: 163/336 (2.9/6.0)
Vogtland
Advertised Drop: 1.6/1.0 (40.6/25.4)
(RacerDre)
Zeal X-Coil
Advertised Drop: 1.0/1.2 (25/30)
Key Information
OEM
Spring Rates?
Eibach Pro-Kit
Eibach Sportline
H&R Sport
Progress
(CarDemon)
Skunk2
Spoon
(macks75)
Sprint
Swift
(Jimmy101)
T1R S-Coil V2
(aj-racing.com)
Tanabe DF210
(jits14)
Tanabe GF210
(4dr4life!)
Tein H.Tech
Tein S.Tech
Vogtland
(RacerDre)
Zeal X-Coil
