Oil filter stuck on and SHREDDED - any suggestions?
https://i.imgur.com/LwewDiI.jpg ... I think the last owner must have had the entire zoo over to tighten this. Now after using every tool known to man I'm left with these results. Any suggestions would be greatly appreciated.
welp just bought this tool - https://bogertaviation.com/products/...to-1500-in-lbs
I'll see how it goes.
Maybe it's possible to swap out the bolts that the tool uses with some much longer ones... I'm not sure.
Did you try using some larger pliers on the remaining top part of the filter?
Try going back to the screwdriver in the holes method... but don't use the hammer. A hammer produces high but instantaneous power, which goes into the ripping the sheet metal of the filter than turning the whole thing.
Lift the car a little higher and get a little pipe that fits over the handle of the screwdriver to use as a breaker bar. This should allow you to apply a more consistent torque to it. If possible, use another screwdriver (and pipe) on the other side of the threaded pipe to spread the power around instead of just one or two holes.
Still impatiently waiting on the tool. Will update ASAP- likely getting it tomorrow... I'm still amazed at how stuck on this thing is. I bent 3 screwdrivers trying to use that technique; and that was the last of my options I exhausted.
Well, thanks to that tool i posted up top it was removed in 5 minutes. And that was taking my sweet time. Before it got to this step I had used, my hands, hands and sandpaper, strap wrench, clamps, and about 3 other techniques until I gave up and went to the screwdrivers. I went through 3 of those until the filter was just destroyed. This tool took it off with relative ease - It was the only thing allowing me enough torque to get it off. I still dont understand how it was so tight on there because it wasn't cross threaded. I also used a hammer and chisel to try and wack it out but it started chipping through the metal on the filter.
It would have been easier to take it to the damn dealer has I known i'd go through this
- Anyways if you're in the same situation this tool will likely get you out of it.
This! And people wonder why I still change my own oil. The other day I was buying oil at the dealer and the parts guy told me, "you know, we can change your oil FOR you for less than you can buy the oil and filter." Sure, as long as I don't care what oil you use, and assuming I don't mind never being able to get the filter off again. Been there, done that.
I was told by a marketing exec of a large oil company that their consumer studies showed that most people who change their own oil do so NOT to save money, but do so because they know the job will be done right.
You're one of those people and me too.
.. lol
