FS: 2009 Fit GE8 OEM Ignition Coil Packs
Old 12-06-2018, 04:50 AM
zenkimr_S's Avatar
For Sale. 3 OEM coil packs from a 2009 Honda Fit GE8. I was having misfiring issues with cylinder #2 so I decided to replace all 4 at the same time. Turns out cylinder #2 spark plug came loose causing the misfire and brunt up the boot on coil pack #2 a little bit (picture added below). I know these are expensive from the dealer, but these might help someone here. These had 132,XXX miles on the car before I replaced them with Denso coil packs. These 3 were working perfectly fine when replaced. Asking $15 each for the working 3 coil packs and are sold as is. Coil pack #2 you can take for free if you purchase the 3 together, but you need to use this on your own risk. I'm just going to throw it away if buyer does not want it. Located in Glendale, CA.
JCLW
08-14-2023 04:41 AM
nickroz
02-26-2017 08:21 PM
Mtwalenciak
12-23-2014 10:04 AM
RomeoJunior
10-20-2014 03:38 PM
dtgrosse
07-17-2014 01:04 PM
Quick Reply: FS: 2009 Fit GE8 OEM Ignition Coil Packs
