DIY - Door Sill install
Old Jun 3, 2006 | 11:12 PM
Chikubi's Avatar
Ok, so I thought this might make a nice DIY since I've seen a number of people here express interest in getting some aftermarket door sill covers to protect their Fit's sills, which are just the bare paint and really susceptible to getting scratched it seems. There are a few varieties of sills being sold by the vendors here and other places -- Mugen, Mugen knock-offs, JDM Honda, Last Station, etc. All are pretty much the same thing -- flat panels that are stuck on with some kind of adhesive tape/backing. This is good because with a little effort you can apply them yourself and save some money, which is what I did. Here's how to apply them:
**** STANDARD DISCLAIMER -- neither I nor FitFreak.net is responsible for any damage you do to your car following this DIY. While the install is not difficult, you can botch it if you're not careful, so be forewarned now. If after reading this you don't feel confident enough to install these yourself, by all means go to a dealer/professional installer to have it done. It's money well spent compared to doing an F'd up job. That having been said, let's get going!
** Please read all the steps below thoroughly first before starting to apply your door sills. It pays to know in advance what the next step is so you don't get confused once you start and blow the install.
ITEMS YOU'LL NEED
- 1 set of door sills (I bought the JDM Honda ones b/c they're JDM and made for the car, any adhesive backed sills are fine though)
- clean, damp rag to wipe off the car's door sills
- another clean rag to wipe the door sill area w/ alcohol
- bottle of rubbing alcohol to use to degrease the sill area. Don't use anything stronger or you risk damaging the paint, you've been warned.
- felt pen (optional) to mark the sill area to help align the door sills when applying. Make sure you can wipe it off when you're done. Use at your own discretion.
INSTALL
1. Ok, as you can see here, the door sill area gets pretty dirty with everyday use, thus the need to do some quick cleaning before applying your new sills. Be warned, if you skip this step and just stick them on, you may end up regretting it later when they start to pull up from the dirt/oil/etc not allowing the adhesive to stick properly and strongly. It only takes a minute or two to clean the sill, so it's time well spent.
2. First, wipe down the sill area with a water dampened rag like this. Make sure you get all the dirt/dust/ etc that's there, or like I said above, your sills won't stick as well as they should.
3. Next pour some rubbing alcohol onto a clean rag and wipe the sill area down again like above. This gets rid of the oil/grease/grime and leaves the paint really clean so the door sill's adhesive grips as best as it can. Be careful not to touch the cleaned area with your fingers or another dirty rag, or you'll have to clean it all over again.
4. Take the door sill that was made for the door that you're working on and test fit it to see where you want to apply it and how it fits/lines up. DON'T take the backing off just yet, or you'll be stuck (literally) with the sill maybe where you didn't plan it to be. Anyway, just lay it on the sill area and move it around 'till it looks right to you and balanced in the space. Once you have it where you like it, you can use your felt pen to put just a small dot on the car where the front end of the sill is so you can line it up again when you go to apply it for real. DON'T draw a line around the sill because it's not necessary and if you can't clean off all the ink you'll end up with that line around the sill forever, which looks like crap -- you only need a tiny dot. I personally didn't use a pen when I did my sills, but I mention it for those who may need a guide when applying their sills so they line up. Again, use at your own discretion!
5. Here's a photo of the back of the sill. It's just paper over the adhesive like any sticker you've ever seen/used since you were a kid. Be careful though, as the glue on these things is not like any glue on other stickers. It's REALLY strong, and once stuck you ain't getting it off without a fight or damage to your paint, perhaps. Caution is the word of the day with this stuff, so take your time with the next steps of the install. You've been warned!
6. Peel back about 1"-2" of the backing off of the door sill, like above. DO NOT peel it all off or you're screwed, just an inch or so is all that's needed.
7. Next, take the tab you just pulled back and fold it at a right angle to the side of the sill that's AWAY FROM THE CAR, thinking as if the sill were installed. See the above pic.
8. CAREFULLY lay the sill in place and line it up in the sill area so it looks like when you placed it there originally to test fit it. If you used a dot, then line the edge back up with the dot to get it where you had it before. DO NOT PRESS ON THE SILL YET WHERE THE BARE ADHESIVE PART IS, OR YOU MAY END UP WITH A MIS-STUCK SILL! Only once you are TRULY satisfied with the placement of your sill, should you then press on the adhesive part to start applying the sill. I cannot stress this enough -- only stick it once it's where it needs to be, and do so carefully so as not to upset the alignment of your sill on the sill area. If you don't follow this advice then you'll screw the pooch, and good-bye Mary to that nice professional-looking install you dreamed of. Honestly, be careful!
9. Ok, we're in the home stretch now! As in the photo, while holding down the sill so it doesn't move, CAREFULLY pull the backing out and away from the sill area about 1"-2" at a time, then press down the newly exposed adhesive part to the sill area. Continue to remove the backing in this way until you've reached the end and it's all off and the sill is all stuck in place. Once you've got it all off, Congratulations!, the hard part is over and you can relax and breathe easy. Another word of caution, though -- DON'T just yank the backing away in one shot, or you risk pulling your sill out of alignment and getting it mis-stuck where you didn't plan on. You do this and again, bye-bye pro install.
10. Now the easy part -- using the shiny side of the paper backing you just removed, firmly press and rub it back and forth over the whole length of the sill like in the photo above. Using the shiny side insures that you don't scratch the sill or paint, and also lets you apply a lot of pressure while rubbing to insure that the adhesive is well stuck and in contact with the sill area under the sill appliqué. Once you feel you've rubbed enough, you're done! Not too bad, huh?
11. Step back and admire your work and newly installed sill. Looks good, doesn't it? And you did it all yourself! Go back to step 2 and repeat for the other 3 sills, and once that's done you've finished the lot. All told, it took me about 30 mins to do, and that was even taking pictures while doing it. Sweet!
Old Jun 3, 2006 | 11:27 PM
SheepNutz's Avatar
There sure is a triple posting bug going around tonight. Nice DIY tho.
Old Jun 3, 2006 | 11:29 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
hey man, i love the little bamboo yoga mat.. hehe .. awesome writeup too! where did you get your stills?
Old Jun 3, 2006 | 11:43 PM
aziatiklover's Avatar
Master FitFreaker
very nice write up bro thanks for the help
Old Jun 4, 2006 | 01:09 AM
Nila's Avatar
instead of the felt pen, you could use a post-it note to mark the area.
nice to see that it's not hard to diy, been thinking about getting a set, thanks for the write up
Old Jun 4, 2006 | 01:39 AM
Chikubi's Avatar
Thank you very much! I'm glad it'll help people with their install. I got the sills from Ben at AJ Racing here in the Vendor section. Nice price and really good fast service, I highly recommend him. The JDM sills are thick plastic and seem pretty durable -- I didn't think they would scratch as easy as metal ones, so that's part of the reason I picked them. Also, good idea about using the post-it note, definitely a better solution I think if you need a guide.
Old Jun 4, 2006 | 02:58 PM
dougiepants's Avatar
Avid FitFreak Poster
great write up
Old Jun 17, 2006 | 01:22 AM
StormSilverGD3's Avatar
Nice write-up and a tasty mod. I think I'm going to get these sills for my new Fit.
Old Sep 19, 2006 | 12:46 AM
docjim2's Avatar
Zeta Products
make sure that if you use Zetaproducts that u have extra adhesive products available: the door sills just do not stick!!
I have to keep an eye on each entrance to make sure that I do not loose the product on the parking place!! The product was recently discounted and now I know why
UPDATE: read my other post. The Zetaproducts people are great!!
Old Sep 19, 2006 | 12:52 AM
Not true for all of their products. I've install the dash trim, HVAC trim, door pull trim and arm rest trim and none of those pieces had adhesive issues.
Preparation is key. If the surface was slightly dirty it will affect how well the product sticks.
I don't think it's fair to slander them like that. Did you try to contact them about the issue? Did you make sure to use alcohol to completely clean the surface?
Old Sep 19, 2006 | 01:13 AM
docjim2's Avatar
preparation
of course the prep is the key: I installed the Mugen visors (except for the visor-clip problems went w/o probs) at the same time and one of the products (the passenger sice) WILL NOT STICK!! Will have to go to Ace Hardware and try and find more DOUBLE SIDED TAPE!!!!!
Maybe that is why the product from ZETAPRODUCTS were on sale!
Old Sep 19, 2006 | 07:26 PM
koolkevin1107's Avatar
thnx for the instructions i used them once i got my door sills in. U like?
Old Sep 20, 2006 | 12:47 AM
Chikubi's Avatar
Lookin' good! Nice to know my writeup was useful to someone. Good choice on your Fit's color too.
Old Sep 21, 2006 | 03:09 PM
docjim2's Avatar
door sills
Yeah, I was installing the Mugen sills at the same time using the same cleaning technique: Zetaproduct's Angelo e-mailed me and I am watching the sill prob. They back up their products to the hilt! Good people: sorry maybe I was a bit blunt?!
Old Nov 23, 2006 | 09:37 AM
epin's Avatar
The first thing that out from my brain after looking trough the 1st pics... I think that the sill was -upgraded- to the bamboo mat and cut'em out with fit-sill pattern.. Have an idea guys??
Btw, nice DIY...
Old Dec 12, 2006 | 11:36 PM
Gordio's Avatar
Got a link where the thread starter got those? I love that look.
Old Dec 12, 2006 | 11:46 PM
Gordio's Avatar
Old Dec 14, 2006 | 01:51 AM
Chikubi's Avatar
heh, I should pay more attention to the threads I start. Yeah, those are them, though I got mine from Ben at AJ Racing at the time. They're good sills and are holding up great -- look the same as when I installed them.
Old Jan 10, 2007 | 02:01 AM
kelvin Yu's Avatar
where do you get the door sills ?
I reall want to get it
Old Sep 11, 2007 | 07:43 AM
golly's Avatar
Smile Part Number for JDM Plastic Door Sills
Hi,
Got my JDM silver plastic sills from A-J Racing yesterday, and installed them today. Thanks for the fast, friendly service!
If anyone is traveling to the Asia-Pacific area, the part number is 08F05-SAA-001. The box calls them "side step".
Thanks for the instructions, Chikubi!
jnesselroad
43
May 12, 2014 08:25 PM
vpark
Mar 7, 2013 04:53 PM
Blaw
Feb 2, 2008 12:42 PM
Chikubi
Oct 30, 2006 04:57 PM
Chikubi
Jun 3, 2006 11:12 PM
