lowered ge8's get in here!!! please :)
Old Feb 4, 2012 | 03:18 PM
superdat1's Avatar
Arrow lowered ge8's get in here!!! please :)
hello fellow fitfreaks. I lowered my '12 yesterday on eibach sportlines. I thought having the axle popping out was going to be my main concern but i guess not...
my ABS and VSA light are on
Ive done a search and it seems there are a handful of threads with people who have/had the same problem; however, all of those threads have loose ends. No one posted their solutions to the problem.
If anyone has had that problem can you please chime in
Bringing it to the dealer is my last resort but if im left with no choice then i will. So please dont suggest that first thanks all!!! happy superbowl weeekend
Old Feb 4, 2012 | 03:33 PM
Btrthnezr3's Avatar
Perhaps you stretched the harness or something when you lowered it?
Old Feb 4, 2012 | 04:36 PM
FittedOnEm's Avatar
*watching
Is this an issue for all fits with vsa?
Old Feb 4, 2012 | 05:43 PM
jdmjunkie561's Avatar
Well that's weird , I would try to disconnect the battery and reset it to see if that does the job, and if they come on again then you would have to see what u did to make those go on ! I don't have the vsa since ingot the sport without navi and my abs never went on when I lowered mine so I wouldn't know why that then on !
Old Feb 5, 2012 | 07:32 AM
fortunecooke's Avatar
Ge8- gd3 coilovers interchangeable???
I have a gd3 and I wanted to know if any ge8 adjustable coilovers would be I interchangeable between the two generations, the reason being is because I found a set of coilovers for cheap but they are for a ge8 and I have a gd3. If anyone could shed some light ib this I would appreciate it thanks
Old Feb 5, 2012 | 01:56 PM
doctordoom's Avatar
Supervillain
Did you reconnect the sensors?
Old Feb 5, 2012 | 03:28 PM
FIT4thetouge's Avatar
Funny...same thing happened to me a few days ago when I put my coils on. TC light is on and it seems it's disabled, and I have an ABS light. Everything was connected correctly, so I wasn't sure where the warning lights came from.
Old Feb 5, 2012 | 03:38 PM
inkster's Avatar
My ABS light came on a few days after lowering it. So I took it to the dealer not mentioning about the drop, they found one of the sensor failed and replaced it under warranty.
Old Feb 5, 2012 | 07:43 PM
Cocowheat's Avatar
must not of been a very noticable drop if the dealer didn't even catch it.
Old Feb 5, 2012 | 08:17 PM
BlueBoogers's Avatar
Or the dealer knows of the supreme court ruling telling them they have to prove an aftermarket part caused a part failure under warranty. The sensor should not be effected by a drop just like the exhaust would have no effect on it.
Old Feb 6, 2012 | 02:16 AM
superdat1's Avatar
Hmmmh interesting. Any one else have dealership stories relating to this issue?
Old Feb 6, 2012 | 02:26 AM
FittedOnEm's Avatar
Has anyone tried just disconnecting the battery to see if the code will clear?
There has to be more people with info on this, I don't want to run into issues when I lower my 2012 >.>
Old Feb 6, 2012 | 05:56 AM
Black3sr's Avatar
Guy at my garage dropped the rear too quick before I told him to disconnect the APS sensors. So the wire on one was stretched enough to break it. Next time at dealer they replaced under wty. And yes they did see the springs.
Old Feb 6, 2012 | 11:16 AM
superdat1's Avatar
That didn't work for me. But when you do lower it, make sure you don't drop the rear axle any further than it needs to remove the spring/strut!
Old Feb 6, 2012 | 11:17 AM
superdat1's Avatar
Thanks for the reply! I guess ill just take my chances with a dealer then
Old Feb 8, 2012 | 05:44 PM
superdat1's Avatar
No luck at the dealership! I
they want $270 to replace it. It was definitley the stretched out cable. Might try my luck at another dealer or attempt it myself
Old Feb 9, 2012 | 04:57 AM
Black3sr's Avatar
I would try another dealer first. Good Luck
Old Feb 9, 2012 | 07:53 AM
Btrthnezr3's Avatar
And if no dice, see how much the part is on bernardiparts.com. Maybe you can do it.
Old Feb 9, 2012 | 10:08 AM
x_25's Avatar
The light will go out the next time you start your car and the system is working. Since I don't use TPMS sensors I have to disconect the ABS pump conector to turn off my traction control when I need it of (not often with better tires) and the lights go out once I reconect it (I always connect it or disconect it with the car off)
Old Feb 10, 2012 | 01:09 AM
superdat1's Avatar
thats what im going to do most likey
i found the part for $85. the dealer was charging $120. It doesn't seem hard to replace. Sucks because it comes as one assembly. My sensor if fine which sucks because its like a waste of money. I'm going to find where the wire broke and just splice a new wire in. Theoretically it should work But if not, then $85 it is!
great, i wont have to go to the dealer to get the light reset or anything! thanks for the tip
BraytonAK
Nov 17, 2013 02:14 AM
Turboem1
Jun 30, 2011 09:13 AM
123fit
Jan 10, 2010 06:07 PM
kmschwem
Mar 27, 2009 08:17 PM
unphit
Dec 7, 2008 01:23 AM
