2007 Fit over heating HELP PLEASE!!!!!!!!
Old Feb 4, 2012 | 03:50 PM
Jeff Pirkey's Avatar
My basic 2007 Honda Fit is over heating. I have replaced the radiator, timing belt, thermostat, both temperature sensors, and water pump, all with Honda factory parts purchased from the dealer. The car is still overheating. Does anyone have any ideas as to what could the problem be? It does not yet appear to have a blown head gasket or cracked head or block. Any suggestions?
Old Feb 4, 2012 | 04:53 PM
Texas Coyote's Avatar
You may have an air pocket in the cooling system.... Try burping the baby by finding an area where you can park where the left front of your elevated and the radiator and cap is higher than the rest of the system... Crank the engine up and let the engine run at an idle the radiator cap removed until the cooling fan as kicked on once or twice and the water level at the cap should go down and you can add more water.. If you have someone sit in the car to rev the engine to 3000 RPM, so that coolant will be pulled from the radiator and into the engine so you can add coolant to the top of the radiator before replacing the cap... I have had the same problem on other cars and since I have always parked with the front of the car raised high when adding coolant.
Old Feb 4, 2012 | 07:17 PM
Btrthnezr3's Avatar
Have a local mechanic do a head gasket test. It's easy for them and requires a little pump and some special fluid. If that comes up negative, radiator.
Btrthnezr3's Avatar
We had a car overheating and tried to burp, flush etc but ended up replacing radiator and it fixed the issue.
Old Feb 5, 2012 | 10:08 AM
I replaced the radiator last month with a new Honda radiator. Is it possible to get a bad radiator?
Old Feb 5, 2012 | 10:48 AM
Btrthnezr3's Avatar
Argh I didn't see you had replaced the radiator. Do you know if the hoses were replaced and or the rad cap?
Old Feb 5, 2012 | 11:06 AM
Hootie's Avatar
First and foremost, was the coolant for the cooling system ever replaced prior to the overheating and what was its level when cold? Its usually recommend by Honda to have that taken care of ever 60k miles or 5 years; which ever comes first.
Secondly, the Fit doesn't have a timing belt, it has a chain. If you paid for a timing belt (and not a serpentine belt) you got ripped off.
Did you get the radiator pressure tested prior replacing it? Did you ever pressure test the radiator cap or check the thermostat's and fan's state of function prior to replacement?
mat77
Jan 12, 2017 09:48 AM
willfit07
Nov 21, 2016 05:25 AM
john21031
Nov 26, 2015 01:39 AM
ishcm
May 3, 2014 05:06 PM
Krystyne
Sep 30, 2005 04:36 PM
