Sponsored by:
Sponsored by: CARiD
A/C Not Working
Old Dec 28, 2006 | 08:00 PM
TOPHER1's Avatar
Thumbs down A/C Not Working
It just stopped working a few days ago. When I press the A/C button, it lights up for a moment, then shuts off on it's own while still being pressed. If I press it and release quickly, it turns on then off right away. It does this on every setting, after trying many different variations (temperature, circulation, vents). I've only had it for 3 months. I'm just glad it's not summer! Other than that, I've had no other problems with my Fit.
Old Dec 28, 2006 | 09:36 PM
FitFever's Avatar
I have the same problem. The a/c switch is broken, so the dealer ordered me another one. If you are in a bind, you can depress the a/c button and wedge a piece of paper in the crack to keep the a/c button locked into the on position!
Old Dec 28, 2006 | 10:39 PM
TOPHER1's Avatar
I just tried it out again to see exactly what the problem is. When I hold down the A/C button, it lights up and stays lit until I release it, and it pops back out to the original "off" position. The button will not stay depressed and locked in the "on" position when I release it. I'll let the dealer know about it, and see what they will do to fix it (when I take it in for my first oil change).
Thanks for the tip FitFever. I'll do that until I take it in for service.
grassmunk
Jul 30, 2025 09:34 PM
Wingnut Warrior
Jan 26, 2018 07:44 AM
fithawk
Sep 11, 2015 02:43 AM
