Swapping the rear turn signal and reverse light
Old Jan 22, 2007 | 08:19 PM
j5ive's Avatar
I don't know if I'm the only one who is bother by the turn signal being on the inside of the reverse light on the back of our cars. I know function wise it doesn't matter, but to me it just doesn't "make sense".
Anyways, I got around to swapping them around last night. It was definately not as easy as I had hoped. My recommendation to others who want to do this is, don't. It's not worth the hassle. But if you really do want to, filed down tabs on the hold holders is the best way.
I ended up cutting the harness and swapping them because it looked like at least one of my connectors would not reach its new location, and I would have to cut the wires to extend them anyways. But who knows, maybe you'll have enough slack in your car to not have to cut any wires.
Anyways, here are the results:
Close up of swapped bulbs
hazards (turn signals) on
reverse lights on
More details of the issues and alternate methods can be found at this post on my blog.
Old Jan 23, 2007 | 09:43 AM
4dr4life!'s Avatar
Thumbs up
I actually did this to, I've always wonder why Honda would put the reverse light on the outer and the signal on the inner part
What I did was swaped the wires & bulbs around to make it work. As you said though the driver side is going to be short, all I did was detach the wire harness holding it in place for it to reach. I have pictures but there at home right now.
WhiskeySix
Mar 24, 2014 07:57 PM
JazzTune
Jun 6, 2010 05:54 PM
setter11
Jul 27, 2009 04:00 AM
jman245
Jul 21, 2007 03:30 AM
jman245
Jul 10, 2007 05:29 AM
