Sponsored by:
Sponsored by:
quadruple switch console
Old 02-13-2013, 12:26 AM
gold-civic's Avatar
Does any fit have this console were i can install 4 switches?
or is there any tuner who offer this for a LHD?
Old 02-13-2013, 09:03 AM
jnesselroad's Avatar
I believe that's for a civic si. I don't think it will fit our car, but I would love to be wrong.
Old 02-13-2013, 12:26 PM
gold-civic's Avatar
this pic is from a rhd console for a rhd fit
Old 02-13-2013, 12:45 PM
Oh man, now I gotta get this! Can you post a link to where you found this? I'll search for it too tonight. I'll find out what it takes to make this work.
Old 02-13-2013, 12:59 PM
gold-civic's Avatar
no problem
Honda Jazz GE Start Button Switch - Zerotohundred.com
i need somethink like this, my 3 ports are in use and i would like to install a set of foglights.
this foglights have a switch which have to be install there.
Old 02-13-2013, 01:29 PM
FitStir's Avatar
I saw that on a pic you posted that you have all 3 OEM slots filled... what's are the spots/switches for? Headlight adjustment, VSA, & what else?
I had no idea that was for a GE8 either.... I'm skeptical, since the JDM GE8's have smartkey, I thought the start button was different.
Interested if this is available for LHD, I don't need or want it... just curious.
Incase you can't find an OEM panel, you could just cut a rectangular hole under the 3 OEM switches you have or somewhere else on that panel for the fog switch. Iirc, it should be a relatively simple mod to make the extra switch fit. That should work. Or using an aftermarket switch, like those round toggle type switches.
If not you could get the USDM headlight stalk (which has the fog light controls on the stalk), and try and re-wire or re-route the fog controls to the stalk... just throwing out possible solutions.
Old 02-13-2013, 01:36 PM
gold-civic's Avatar
yes VSA, headlight adjustment and the button for the start/stop function
i do not like the aftermarket switches, love more the oem solution.
Old 02-13-2013, 02:14 PM
FitStir's Avatar
Thumbs up
Originally Posted by gold-civic
.... and the button for the start/stop function
What does it start/stop?
I agree with you on OEM... That's why I mentioned the USDM OEM stalk.
Hey since you're over in Europe, any chance you can post a pic of your "refresh-mode", I hear you guys still have it on the GE8's where as they took it out on the USDM models (made the seat backs larger so it doesn't work).... when you get a chance.. ty.
Old 02-13-2013, 02:30 PM
gold-civic's Avatar
a sample, when you stand before the traffic lights and you put your gear at neutral the engine stops.
if you use now the clutch pedal the engine starts again.
with the switch i can switch this method of.
what do you mean with refresh-mode?
Old 02-13-2013, 02:58 PM
FitStir's Avatar
Thumbs up
Damn... you have a hybrid? or straight petrol? I've only heard of that auto-stop feature on hybrids like the CR-Z. Nice...
Refresh (bottom pic)
Where the front seats fold flat/flush with the rear... kinda like a bed.
Old 02-13-2013, 03:32 PM
gold-civic's Avatar
I have no hybrid, it is a petrol yes.
This feature is new and only the 1.2 have this.
Do not know if my jazzy has this feature, i will try it.
Old 02-15-2013, 09:16 AM
That switch replaces a whole panel on the rhd. At least on ours here in the us, our switch panel is part of a larger l-shaped piece that goes down and around the steering wheel. No luck on getting that piece for the us models at least.
Old 02-18-2013, 01:52 PM
gold-civic's Avatar
our panel look like this
sorry, also no refresh-mode on our GGs, also the back seat is larger.
Old 02-18-2013, 09:54 PM
ampete04's Avatar
I don't know if this is what you have in mind, but it gives you 4 switches.
Old 02-18-2013, 10:16 PM
ampete04's Avatar
Might be able to import from here
Old 02-21-2013, 12:22 PM
gold-civic's Avatar
Nice option, gut my Jazz does not have a eco option
SilverEX15
08-08-2014 08:27 AM
damatick
05-26-2011 10:56 PM
OhNineFIT
09-03-2009 12:19 AM
FELIXY69
09-02-2008 04:15 AM
hazzard
11-30-2006 08:16 PM
Quick Reply: quadruple switch console
