OIL, filter, maintance minder questions
Old Apr 29, 2007 | 12:45 AM
  #161
milano sol's Avatar
Originally Posted by Sport
Are you sure? Because I've never read that in the book. As far as I know, once it's time to change the oil, you also change the filter. And both should be done roughly every 5000mi/8000km. BTW, it won't just read "A". The minder will have a corresponding number alongside the letter ie. A1, A2, etc.
100 % positive. i have the book right here.
A : Replace Oil
B : Replace Oil and Filter
and so on....
there doesnt have to be a number. the numbers are just sub items for extra stuff that needs to be done. either A or B will pop up not both. (Page 173 of owners manual)
1.Rotate tire
2.replace filters
3.replace tranny fluid
4.replace spark plugs
5.replace coolant.
the only one that would come up regularly would be rotate tires.
so yeah according to the manual only replace oil filter with oil change when B pops up. but like i said i always replace my filter at every oil change anyways.
HOWEVER!!! i am in the US and the Canadian manuals and MM's might be slightly different.
Old Apr 29, 2007 | 11:18 AM
  #162
Bent4god's Avatar
Arrow When to switch to synthetic oil?
Is there a "best time" to switch to synthetic?
Thanks,
Grampa
Old Apr 29, 2007 | 12:05 PM
  #163
valdesebent's Avatar
I switched at 15K at my second oil change. Most agree that you should run the regular and clean out the debris to start.
Old Apr 29, 2007 | 12:07 PM
  #164
Fit of RAGE's Avatar
i changed it at 10,000km (i just did it)
I used Mobil1 and an OE Honda filter. I IMMEDIATELY felt a differance. There's NO more valave noise when cold. The car seems like it's working less and more free-reving. (It could be just that i'm more sensitive to it, but i really do feel a differance)
Old May 1, 2007 | 02:44 PM
  #165
KnifeEdge_2K1's Avatar
hey guys, anyone try using the usdm s2k filter on their fits ??
i called up a couple dealerships around toronto and they all say the filtech A01s arn't made anymore and that they only have the honeywell A02's ...
Old May 1, 2007 | 03:48 PM
  #166
Garismatic's Avatar
Yes, it's all I'll use.
Old May 3, 2007 | 12:04 AM
  #167
you use the usdm s2k filter on your fit ??
how many times have u used it (# of oil changes)
any problems with leaks ??
how's the fitment ??
I'm thinking of using either the s2k filter or a bosch filter if i can find one in the correct size.
Old May 14, 2007 | 02:59 PM
  #168
pokey's Avatar
Question oil change?
My new fit only has 1500klm,I'd like to make an oil change to 100% synthetic oil and appropriate filter (amsoil) is it too soon or should I go ahead and do it before an upcomming 2400klm road trip? (fit dx 5 speed manuel.Thanks Missfit.
Old May 14, 2007 | 03:30 PM
  #169
StormSilverGD3's Avatar
You will get different responses from different people.
At this day in age, I've never had any problems switching to a synthetic oil on a new car. I did so at just 1000miles on my S2000 and if I was going to run syn in my Fit I would not be concerned about doing it too soon either. It's your call really.
Old May 14, 2007 | 03:48 PM
  #170
pocketrocket's Avatar
I've heard from various honda tech's on here and where I purchased my Fit to NOT change the oil until the 5000 mile mark.
I'm not too sure why, but maybe just wait until 5000 miles to be safe?
Old May 14, 2007 | 03:49 PM
  #171
cliu's Avatar
it probably wont kill the car to leave the dino oil in the car until 3000 miles. just leave it til then to be safe and change it to synthetic after that. this way you can be sure about proper break-in now and have the peace of mind about the synthetic oil later.
Old May 14, 2007 | 03:55 PM
  #172
Spoon-Fit's Avatar
Check this link...makes sense to me...u decide if he makes sense or not.
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
Besides..does the Fit engine really need syn oil?
I can understand high stress engines like Evo's Sti's S2's etc etc.
I'd went with Mobil 5000...
Old May 14, 2007 | 06:48 PM
  #173
cashondeb's Avatar
I'd wait until the oil light goes to 5%, then decide. The oil in it right now should be good enough! I've had no problems (hit the 1,000 miles), and am going to wait until it goes to 5%!
Old May 14, 2007 | 09:17 PM
  #174
doogiefish's Avatar
Just changed mine today for the first time. Maintenance Minder hit 15% at 5747 miles with the factory oil. Refilled with Mobil 1 Synthetic and a Mobil 1 filter.
Old May 14, 2007 | 09:53 PM
  #175
pokey's Avatar
Thanks for responding so quickly with your opinion. Missfit.
Old May 14, 2007 | 10:32 PM
  #176
i wouldn't do it untill at least 10,000km. I did mine at 10,554km. I switched to Mobil 1 5w/30. (with the OEM Honda oil filter)
Old May 16, 2007 | 03:10 PM
  #177
bigtymer8700's Avatar
Something weird
Well i was driving home today and all the sudden my maintanence light starts blinking I check and its just my oil life its down to 15%.... havent gotten around to changing it but then the light went off and this i saw this...
maybe its normal but just wanted to make sure
Old May 16, 2007 | 03:22 PM
  #178
spreadhead's Avatar
Yes it's normal, it's all explained in that little book that came with your Fit.
Old May 16, 2007 | 03:40 PM
  #179
really the A and the 1? I was looking thru the manual and saw no explanation for it
Old May 16, 2007 | 03:45 PM
  #180
spreadhead's Avatar
pages 168-173
