LED Dome Light Questions
Old Nov 11, 2007 | 01:59 PM
baseexcisionrepair's Avatar
Hi all--
I've been searching through this section and through Google, trying to gleen as much as possible about ways to convert to an LED dome light in the Honda FIT. There appear to be many options available:
LED Dome Lights
Amazon.com: White HONDA Civic replacement interior dome light bulb upgrade LED dome light by Led 92-95 HONDA Civic High Intensity Super Bright Cube 9 LED 1.25 White Color Dome Light interior dome light light bulb upgrade: Automotive
High Power LED Festoon Bulb Specifications
Auto Indulgence
A&J Racing :: Interior :: Luxer 1 LED Room Light for Honda
Battle Endless Performance
Unfortunately, some of the dealers mentioned above have several choices and it is not clear which of these are best suited for the Honda FIT. It looks like most of this stuff is generic and might work in the FIT even though it is listed for the Civic. Does anybody know what dimensions work best? Thickness, for example, must be very important. Some of these choices offer foam backing and so does this have to be removed in order to fit in the FIT? And what about length and width. Do I go with the small or the large size? Flexible or rigid?
None of these points are clear, so I thought I would start yet another thread in the hopes of shedding some light on these lights.
Thanks
Old Nov 11, 2007 | 02:23 PM
smatts's Avatar
Honda Fit Forums Moderator
I'm using the T1R LED light from AJ racing, it's a bit pricey but it's a really great kit with plenty of socket adapters and sitcky pads to make it work in both the dome or trunk area. It is a really bright white light, 12 leds I think.
Old Nov 11, 2007 | 03:44 PM
arsonall's Avatar
^^^^same as above, works well in both lights. if any of the others are like the t1r, then they have multiple plugs for whatever kind of plug/light your car has.
Old Nov 11, 2007 | 04:01 PM
osborne's Avatar
I use the Luxer1 LED Dome. You can view the thread here:
Luxer1 LED Dome Lamp
Old Sep 6, 2011 | 01:23 PM
LeLionNoire's Avatar
Unhappy TG Motoring LEDs
just received a 5 set LED from TG motoring ebay:
LED Interior Packages, Lexus, Toyota, Scion items in TG Motoring store on eBay!
You have to make sure its the 12 led panels (interior) for more light otherwise they got my order wrong and gave me the 6 LED panels instead which are craptastic dull to the point that the OEM lights are brighter
Just giving the heads up.
Old Dec 29, 2011 | 05:58 AM
speeedyracer's Avatar
I used a set from ebay. Plug and play. Took two minutes.
Old Jan 3, 2012 | 10:27 PM
BAUSauto's Avatar
Former Vendor
Old Jan 4, 2012 | 03:55 AM
MNfit's Avatar
LED Lights, Bulbs & Accessories - SUPER BRIGHT LEDS that is where I got all my interior bulbs for my Jimmy and Fit.
Old Jan 11, 2012 | 07:00 PM
iJDMTOY's Avatar
Former Vendor
We have some lights for your car available!
5 Light SMD LED Package
Super Bright LED Car Interior Lights | Honda FIT SMD LED Car Lights
The package above includes 1 pair for the front map lights, 1 piece for the rear dome light, and 1 pair for the rear license plate lights.
***SAMPLE PICTURES***
For those who have the 2007-2008 Honda Fit, since you have only one dome light, you can go with these:
6-SMD D31 Festoon LED Bulb
6-SMD DE3175 3175 Festoon Dome LED Bulbs | 12V Car LED Interior Lights
I personally use these same LEDs in my Civic's interior lights and these are great, they're bright, but not too blinding.
mmitsch
Nov 5, 2014 08:52 AM
fbpearce
Nov 13, 2012 07:59 AM
thejroisgo
25
Jun 30, 2008 02:11 PM
JJAZZ
Nov 2, 2007 05:40 PM
thedeadpoet000
Aug 26, 2007 01:09 AM
