Is there a DIY for installing struts?
Old Jan 28, 2010 | 12:00 AM
Padraic's Avatar
I used the search function in a couple forums and I couldn't find a DIY for installing struts. I know how the fronts come out from the spring DIY, but is there one for the rears? I assume it is simple, but pictures or instructions make everything easier.
Thanks!
Old Jan 28, 2010 | 12:49 AM
SD_MR_FIT's Avatar
its the same for installing lowering springs.
there is in the DIY.
the rears are super simple. take off the caps in your cargo area....undo the bolt.
go to the bottome where your shock is attacted by 1 bolt and undo that and you got it.
really really simple.
but for the fronts the DIY has everything.
https://www.fitfreak.net/forums/fit-...07-08-gd3.html
Old Feb 24, 2010 | 04:07 AM
FITFITFITFITFIT's Avatar
the rear are easier than the fronts
Old Feb 25, 2010 | 02:57 PM
Tofuman's Avatar
Let me know if you have any questions - I just did an install over the weekend. It was pretty easy. What type of struts are you installing?
Old Mar 3, 2010 | 09:16 PM
captainhowdy's Avatar
Unless you are experienced with using a spring compressor, you shouldn't do that part yourself (front). The R&R part maybe if you are somewhat mechanically inclined.
Old Nov 4, 2010 | 03:57 AM
08purplefit's Avatar
U don't need a spring compressor for the fit
Old Nov 4, 2010 | 09:36 AM
shazaam's Avatar
And remember to keep the front rotor/hub assembly propped up to keep the axle(s) in or else you might hate life.
Old Nov 4, 2010 | 06:39 PM
danger69's Avatar
I'd suggest getting a spring compressor for the fronts just in case you ever want to swap back to stock. I had to do that with my coilovers to springs. The rears are ridunkulously easy. Just make sure you have the right tools such as a good allen wrench.
vinnymac
Oct 31, 2010 10:22 PM
kamakurakid
Feb 19, 2009 12:00 PM
DC_Native
Sep 22, 2007 03:31 PM
mimpi
Nov 27, 2006 10:15 PM
sLiVeRwOrM
Oct 30, 2006 07:36 PM
