AC, Defogger, Airbag light
Hi
New GD Sport owner in Seattle
Bought a used Fit last month for a very good price through a friend hookup at a dealer. Now I'm just doing a few bits and pieces on the Fit to clean it up a bit. I noticed that the AC, rear defogger, and Passenger Airbag do not light up. The lights that indicate they are on work but the lights itself do not work when it is dark and I have the headlights on. Is there a fuse I should check or would it just so happened all of them are burnt? Both AC and defog switch do work function wise.
Usually it's just the bulbs that are faulty. When I got my Fit, the AC backlight doesn't go on but the green light works. I took the switches out and it was just loose.
Best bet is to check it out if it's loose, if not then just replace them.
trashercan
02-09-2010 08:14 PM
