Tire, Wheel, Brake & Suspension Welcome to the FitFreak.net Tire, Wheel, Brake & Suspension Forum
Will 15x8 wheels fit?
Old Dec 17, 2007 | 03:50 AM
Sleep_DEPRIVED's Avatar
Hi, i'm eyeing a set of wedsports 15x8 wheels but i'm not really sure if it will fit the car. What offset should i use? I'm thinking about running 215/45 (or 50)-15 tires.
Old Dec 19, 2007 | 05:59 PM
from wat i can see on my 15x7 +40mm, i think you can fit a 15x8
if your tires are 195 width summer or 205 or 215 in all-season.
summer tires have bold shoulders and are usually wider than advertised
expecially when mounted on wider wheels.
As far as offset, i'd say +43 to 45mm range. the rear will most-likely
fit even with +38mm. this is just estimation so do it at your risk.
Old Sep 17, 2009 | 01:06 PM
jim@tirerack's Avatar
Former Vendor
With the 15X8 wheel I think you are going to have some rubbing issues. The 195/50R15 doesn't even fit a 15X8 wheel.
Old Nov 3, 2009 | 06:26 PM
ghettoboy247's Avatar
if u wana be a G, do it!!! hit me up and i'll letchu kno wasups so ppl on honda-tech___ i mean fitfreak dun't start flaming!!!
jes like how every1 said you couldn't run more than 17x7 +40 w/o rubbin back then... i think i proved ma point
Old Nov 3, 2009 | 07:24 PM
Jodele's Avatar
With an 8" wheel, the nominal offset is 36-mm to fit on the car without touching the shock strut (I'm prety sure it will rub your fender well)...you might be able to get away with a maximum of 40-mm offset without touching the shock strut to give a little extra room for the fender.
An 8" wheel with completely FUBAR the suspension geometry and FUBAR your handeling.
Three words - "Don't do it!"
Old Nov 4, 2009 | 05:39 AM
shiez, all y'all too conservative with ure tuning!!! jes too prove a point, i rocked 0 offset xxr's and was able to turn the steering lock to lock and slalom with MINIMAL rub. i think those were 15x8 too
Old Nov 15, 2009 | 03:54 AM
vinn's Avatar
why you guys have to necro bump this? LOL
15x7!
Goettler
60
Jun 29, 2016 10:41 PM
specboy
Aug 15, 2010 02:25 PM
braziers
Jan 30, 2009 05:51 AM
SYMBIOTIX
Mar 14, 2008 08:05 AM
diedwater
Feb 23, 2008 04:12 PM
