Stainless braided brake lines... Worth it?
Old Feb 2, 2008 | 11:34 PM
richard612's Avatar
Do they firm-up the pedal by any significant amount?
Who's making them these days? Only A&J?
Are the rears worth installing? Line pressure on a drum setup ought to be pretty low....
Old Feb 3, 2008 | 01:07 AM
Mr.Ball's Avatar
They are not worth it unless you are planning to go to the track quite a bit.Or you are up grading your whole braking sysem with bigger rotor's and pad's. (save your money)
Old Feb 9, 2008 | 12:39 PM
mrmandmman's Avatar
Once you get 100,000 miles or your car is a little older they are a good upgrade. Much better knowing the rubber isn't going to break, plus they make the brakes feel more solid (personal experience).
Old Feb 9, 2008 | 01:51 PM
Sugarphreak's Avatar
Push My Button
I have a set of these from T1R, putting them in fairly soon.
They didn't cost that much, less than a voltage stabilizer
I plan to spend some time down at the track, I will be using them in conjunction with X3E brake pads. I will post up what I think of the performance they offer.
Old Feb 20, 2008 | 10:23 AM
alim ulama's Avatar
a Steel Braided brake line is a good deal when u're often do some heavy braking, and a high temperature brake pad is worth every penny when u go on a track day.
so upgrade ur brake setup to suit ur needs
-justmy0.02-
Btrthnezr3
28
Oct 18, 2013 07:42 PM
Ein
Nov 30, 2008 02:44 PM
Sugarphreak
Aug 26, 2008 12:36 AM
Yongjin
Apr 17, 2008 03:13 AM
SennaVsProst
23
Feb 8, 2008 04:33 PM
